View Full Version : 69 Camaro RS Update
Taylor1969
02-01-2008, 07:42 PM
Here is the previous link:
https://www.pro-touring.com/forum/showthread.php?t=34529
And some updates:
Getting really close to having the car started now...
Most of the engine wiring is done, brake lines, tranny lines, fuel lines are installed. The exhaust, driveshaft and gas tank is in and a ton of other small items. It is amazing that 4 months have passed, and it seems like not a lot has changed, but the guts of the car are almost completely in place and it should fire up in February.
https://static1.pt-content.com/images/pt/2008/02/IMG_2723-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2724-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2719-1.jpg
Taylor1969
02-01-2008, 07:43 PM
https://static1.pt-content.com/images/pt/2008/02/IMG_2728-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2726-1.jpg
https://static1.pt-content.com/images/pt/2008/02/IMG_2705-1.jpg
https://static1.pt-content.com/images/pt/2008/01/IMG_2709-1.jpg
Code Red
02-01-2008, 07:51 PM
looks good man
dropit69
02-01-2008, 08:15 PM
looking sweet..where did the valve covers and air cleaner come from ?..ive been looking into black and those look killer on there..
Mark Smith
02-02-2008, 04:54 AM
looking good.you must be getting pumped.
hotrdblder
02-02-2008, 05:16 AM
what did you coat the underneath of the car with, nice work
Taylor1969
02-02-2008, 06:05 AM
I used 3m Body Schutz undercoating. It sprays really nicely, adheres well and has an awesome texture. I probably used a total of 4 bottles to do the car.
https://static1.pt-content.com/images/pt/2008/02/4508-1.jpg
It screws directly into an applicator gun that can be reused. It cleans up really nice and is an all around excellent product in my opinion. I think that if you get the white version it is even tintable with paint if you are interested in body matching.
The gun looks like the image below - i picked one like it up for about $25:
https://static1.pt-content.com/images/pt/2008/02/1709-1.gif
You can kind of see the texture here:
https://static1.pt-content.com/images/pt/2008/02/IMG_2713-1.jpg
Taylor1969
02-02-2008, 06:10 AM
They actually came with my engine, but I believe that they are made by proform.
http://store.summitracing.com/partdetail.asp?part=PRO%2D141%2D758&autoview=sku
They look really awesome - the black is eggshell and has a very small amount of texture. I really like them.
Motown 454
02-02-2008, 10:29 AM
Looks Good have you started the engine yet? Underneth looks nice Are those fuel line standard size or larger? Comming along nice
01somta
02-02-2008, 02:16 PM
I really like the look of the Body Shultz, what prep work would be required for new sheetmetal? Would I have to just scuff it up or is a primer required? Also do you need a real big compressor to spray it? Can you spray it on your back, if you don't have a rotissiere?
Taylor1969
02-03-2008, 11:51 AM
The engine should be roaring to life in the next couple of weeks... I am just getting the details done and will then be starting it. The fuel in is upsized from the original - 3/8 instead of 5/16 inlet and regular sized return - both stainless.
01somta
02-03-2008, 12:30 PM
no reply???
Taylor1969
02-04-2008, 06:08 PM
Sorry...
You don't need a huge compressor. I scuffed the sheetmetal and then cleaned it with wax and grease remover. Once that was done I sprayed it. The tube from the gun goes almost to the bottom, so you can spray "almost" horizontally. I would spray the hard to reach places first and then everything else after. Everything I did was done on the lift. I think most of by spraying was done around 45 degrees or so.
