View Full Version : Ls2 camaro dyno video
nc69rs
01-29-2008, 05:43 PM
The car made 436 HP and 403 TQ
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i271.photobucket.com/player.swf?file=http://vid271.photobucket.com/albums/jj125/nc69rs/Camaro%20pics/100_0954.flv">
class67
01-29-2008, 06:06 PM
:cool:
brownz
01-29-2008, 06:14 PM
That sounds BAD A$$ nice car :headbang: :headbang: :headbang:
skeeters65
01-30-2008, 10:37 AM
What has been done to the drivetrain??
Rybar
01-30-2008, 10:47 AM
Nice numbers and car. Post some more pics and specs of it.
nc69rs
01-30-2008, 04:16 PM
A couple more pictures.
https://static1.pt-content.com/images/pt/2008/01/100_0295-1.jpg
https://static1.pt-content.com/images/pt/2008/01/DSC01319-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_0880-1.jpg
Rybar
01-30-2008, 09:22 PM
That's a nice machine, what's all done to the motor?
nc69rs
01-31-2008, 04:00 AM
Basically a stock motor
Only mods. are
238/240 duration 605/609 lift Comp cam kit
Underdrive pulley
1 3/4" Hooker conversion headers
3" exhaust
GTO 6 speed with LS7 clutch
12 bolt rear with 3.73 gears
Northern Goat
01-31-2008, 07:54 PM
The car sounds freakin awesome!!!!!!!
What mufflers are you using?
nc69rs
02-01-2008, 03:17 AM
Its a 3" headman x-pipe with 2 chamber 40 series flowmasters dumped before the axle.
shudog
02-01-2008, 05:42 AM
That's a pretty big cam, didn't you lose alot of low end with such a big duration? Most guys I see run something more in the neighborhood of 224-230 duration...
nc69rs
02-01-2008, 11:30 AM
To be honest, I have nothing to compare it too. No before and after. I did alot of reasearch on the GTO site before making my cam choice. Some commented on only a slight loss, but most were still running a stock gear. Since my car has the 3.73 rear and weighs 700 lbs less than a GTO I decided to go with it. I can tell you that the car accelerates very well without exceeding 3000 rpms through the gears with great throttle response.
shudog
02-04-2008, 04:19 AM
Good to hear you're happy with it. If you ever decide you need a little more, a budget set of heads slightly milled to increase compression will give you more boost back in the low end. Check out www.ls1.com for a ton of posts on heads/cam setups.
Motown 454
02-04-2008, 05:48 PM
Awsome looking car I wish the LS2 was available before I bought my motor. Damm thats nice>
rockertype
02-06-2008, 09:49 PM
That is a sweeeet ride! :kewlpics:
