    Results 1 to 8 of 8
      Cypress, TX
      Replacing upper cowl
      Replacing sides and upper cowl on 69 Firebird. The upper cowl is arched about 1/2" -3/4" to high where it meets the glass. Whats the best method to take out some of the arch? Will placing 50 lbs. bags across the cowl remove some of the arch?
      Thanks- Sims
      Midwest
      Got pics? Normally we screw / clamp everything together to fit, then begin welding..
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Oct 2005
      Odessa mo.
      Quote Originally Posted by oestek
      Ditto sheet metal will creep when welding. Your best bet is to start clamping or screwwing it down at the high point of the crown. Then work your way out evenly to the ends. Before you start welding also hop from side to side with your welds starting at one side and going straight across will some times tend to move the metal slightly in the direction you are going. This is a neat little trick that can be used if you have a gap that is slighly off to open or close it a bit.
      Cypress, TX
      It was actually where the glass meet the upper cowl. Glass touched the panel in the center of the lower windshield. Which raised it about 1/2 to 3/4" off the panels on the sides. I placed 3 sand bags across the panel for 2 days, the bow in the panel is almost completely gone. Everything lines up now. Thanks for the help..
      Sims
      Oct 2005
      Odessa mo.
      Quote Originally Posted by Simbad68
      Sims
      I must have misread your post were you talking about the bolt on cowl panel(vented piece)?
      Cypress, TX
      I guess there both called the upper cowl panel. It's the welded panel under the bolt on panel that the dash panel welds to. The wiper motor also bolts to it. Does that make sense?
      Merritt Island,FL
      Here is a pic of how i do mine.
      Check out my web site.
      Oct 2005
      Odessa mo.
      Yes it does it's usually called the inner and outer panels. My brain wasn't quite digesting which part you were talking about . If you haven't welded it in yet just clamp it in the way I said earlier and you shouldn't have any probs. I was thinking you had welded it in already.
