View Full Version : Who is really using a C5 Corvette Master Cylinder?
brn agn
01-28-2008, 05:52 PM
I've been trying to get a C5 Corvette Master Cylinder to work in my Nova. The difficulty I am having is locating a M12-1.5 tube nut (for the front port) that will work with 3/16" brake tubing. I've called mutliple shops and have visited several parts stores with no luck. How is everyone else making this work?
EFI69Cam
01-28-2008, 06:14 PM
The c5 has 2 6mm lines. The nearly identical 4th gen master has one of each.
Why not use the 4th gen?
brn agn
01-28-2008, 06:39 PM
I like the fact that the lines exit on the left hand side of the master and I already had the master cylinder.
Apogee
01-28-2008, 08:09 PM
I could be mistaken, but my notes show the C5 MC to have the same port sizes as the 98-02 F-body MC which are M12x1.0 (front port) and M11x1.5 (rear port) female bubble flares, just on the opposite side. That might help in your search as those are a more standard size.
Here's a link to a company with pretty much every "standard" tube nut known to exist...at least to me. http://www.fmsiinc.com/brake-line-fittings.htm
Tobin
KORE3
brn agn
01-29-2008, 04:30 PM
The REAR port is definitely a M12-1.0. The front port however appears to be an M12-1.5. I have measured the original tube nut (it is for 1/4" tubing) and the major OD is 11.80 mm, which is the same as the M12-1.0. One last thing I will do is find an M12-1.50 machine nut and see if it threads on the tube nut.
Apogee
02-02-2008, 08:43 AM
Using calipers, measure the minor diameter (ID) of the MC ports and you should be able to determine the threads without a thread gauge or proper tube nut for reference. If it is M12x1.5, the ID should be a nominal 10.5mm [.413"]. If it's M12x1.0, it'll be 11mm [.433"]. Usually you can tell if it's coarse or fine thread visually, but if not, measuring should remove all doubt. An M11x1.5 port will have a 9.5mm [.374"] ID...pretty straight forward if you've got some decent calipers.
Tobin
KORE3
brn agn
02-05-2008, 03:57 PM
Thanks for the info. I measured the ports. The front port (fine thread) has a minor ID of 10.9mm and the rear port (coarse thread) has a minor ID of 10.4mm.
The good news is that I found a place that sells 3/16" tube nuts for both ports. I purchased the tube nuts and they are indeed M12-1.0 for the front port and M12-1.5 for the rear port (I confirmed that they fit correctly).
Brakequip is the name of the company that makes the correct tube nuts. I actually bought a few extra sets, so if anyone else is installing a C5 master cylinder and is using 3/16" lines, let me know.
Apogee
02-05-2008, 05:53 PM
Good info. Thanks for the correction.
Tobin
KORE3
