View Full Version : C5 brake calipers and G-Body brake hoses?
jdpolzin
01-27-2008, 08:11 PM
OK guys, I'm in the middle o my C5 brake/ATS spindle swap on my GN. I noticed that the bolt that holds the brake hoses onto the caliper in different. If I get a bolt for a C5 front caliper, will I be able to use my factory brake hoses? I just bought new hoses so I really hope so! Where is a good place to get this bolt? Thanks! -----Jeremy
shep
01-27-2008, 10:03 PM
you can get the bolts from Kore3 http://www.kore3.com/proddetail.php?prod=10059-01 I could not find them locally, but where I live there are not many C5's. your stock GN lines should work provided that the banjo bolt fits through them and you are able to get a good seal.
HectorM52
02-08-2008, 06:08 PM
THANK YOU - I will be doing this part of my swap soon too!!
Samckitt
02-08-2008, 07:15 PM
What shep said. Factory hoses, C5 bolts & washers, works fine. Call the dealer & get 2 of P/N 11570052, cost $5.28 each, & the washers.
