View Full Version : Big block or Small block?
Mr. B
01-27-2008, 07:26 PM
I'm about to move forward with an engine for my Camaro. I really like big block torque, but a lot of todays small blocks are putting out nice solid power too. I particularly like the Smeding 540 and the Smeding 427. If you have a small block with 500ft-lb of torque or more across the power band, would that be salty enough in a first gen? I'm building a pro touring car, and want to track it from time to time. Is the lighter weight of a small block that much of a difference?
Any real world input would be appreciated.
rickk
01-27-2008, 07:37 PM
LS7.
rickk
chicane67
01-27-2008, 08:38 PM
In short... yes.
A big small block is a good answer to your quandry. And then you have an alloy LS7 that even throws more into the ring. Small, light weight and makes the numbers... with a warranty no less.
dj3
01-27-2008, 09:02 PM
It seems like Protouring and small blocks (especially LS engines) go hand and hand.
1969CamaroRS
01-27-2008, 09:43 PM
I think the large displacement small blocks are great especially some of the LSX engines. But I always wanted a big block so I went with one.
Hard to get the flat torque curve on small block that you can on a mild big block, and torque is what makes driving fun on the street.
Think 500+ ft/torque from idle on...
XTRMEASURES
01-27-2008, 10:23 PM
Im putting a 436smallblock in my 84 GMC truck and my engine builder sayed i would have over 550+hp and over 500+ ft/torque. When he is finish we goin to put it on a dyno to see what it makes.
Im also thinking of putting a smallblock 434 or 436 in my 72 camaro with even more hp and torque (650+ hp).
steemin
01-29-2008, 01:34 PM
I readily admit that I do not have the expertise or experience of many of our board members. And I am suer that most will suggest a LS? engine.
But here is my 2 cents.
I have had several small block cars. Several of these had fairly stout engines.
However I recently purchased a 70 Nova with a
GMPP 572/620 fwhp w/TKO600 and that car is fun to drive.
It just pulls hard all the way to the redline.
I know that it weighs a ton. But I love the TQ that the BB produces.:seizure:
Scott
roadracer55
01-29-2008, 02:07 PM
street vs track, right?
hard to argue against the lightweight sbc when you're going around corners.
hard to argue against the torque of bbc on the street.
6'9"Witha69
01-29-2008, 02:11 PM
You can't copy the sound of a healthy BBC. You can almost copy the TQ with an SBC. An LSX is even better than the SBC. Also, the 3 engines mount further back and reduce in weight in the same order. My ideal setup is an LS402. Cubes + modern efficiency make an unreal powerhouse with very good street manners and mileage.
steemin
01-29-2008, 02:20 PM
Well said:worship:
.Scott
Mr. B
01-30-2008, 03:53 AM
I plan on putting on a carbon fiber hood, cowl, and header panel on, as well as an Art Morrison subfram. I would have aluminum heads and intake on the bb as well. With all those weight savings, wouldn't it offset most of the big block weight difference?
rocketman
01-30-2008, 02:03 PM
well you could build an all aluminum BBC, the best of both, and there right nothing sounds like a BBC.
