View Full Version : Anyone running skinnies and slicks with big brakes?
Vinz68
01-27-2008, 06:57 AM
I'd like to get a set of skinnies and slicks to do some drag racing with my car. I have 13" front rotors with 6 piston calipers , and 12" rears with 4 piston calipers. (Willwood) I am currently mini tubbing and will be running a 12" rear rim. Any suggestions? Thanks Vinnie
Bad94
01-27-2008, 08:34 AM
I have 2 GTO spares, and im going to get a set of 17" front runners. Then for the rear not sure yet.
Borgets have drag wheels that look cool and fit big brakes
4086D9
01-27-2008, 10:22 PM
I was wondering the same thing.....I know my front 15x3.5's have only 1.75" bs so I would imagine it would clear. The rear with 4.5" bs Im sure nothing more than a 12" rotor would fit.
Vinz68
01-28-2008, 09:09 AM
What do you have for brakes? It would be great if I could run a 15" rim.
Benoit23
01-28-2008, 01:04 PM
I’m planning on having 2 sets of rims for this reason, 18” wheels for everyday & a smaller dia for the dragstrip.
I have 13" front disc & I was thinking of getting smaller disc brakes for the rear so, I can run 17x7 front 15x12 rear at the drag strip.
Benoit23
01-28-2008, 01:31 PM
I was just browsing lateral-g.net & found some pics that I thought I would ad to this thread for ideas.
These front runners would be great for the drag strip. What do you guys think?
bad bu 72
01-28-2008, 02:29 PM
i have a 72 buick a body with bear brakes 13in front and 12inch rear at the track i have slicks and skinnies. weld draglites 15 inch they fit if you use a small spacer on the front and back. the front you have to get the wheel out enuff to clear caliper
WayneE
01-28-2008, 02:43 PM
CCW makes a drag pack for C5 Corvettes. It uses 16" wheels all around. The fronts are 16x4 and the rears are 16x10. I had a set for my C5.
https://static1.pt-content.com/images/pt/2008/01/th_DSC04642-1.jpg (http://i145.photobucket.com/albums/r228/Uber55/c5/DSC04642.jpg) https://static1.pt-content.com/images/pt/2008/01/th_z06ontrack-1.jpg (http://i145.photobucket.com/albums/r228/Uber55/c5/z06ontrack.jpg)
Maybe he can provide a set with the correct offset for your application.
www.ccwheel.com
Vinz68
01-28-2008, 03:45 PM
I checked out CCW and they seem to be the route I'm gonna go. 17/4 front and 16/11 rear.
