NOT A TA
01-26-2008, 05:38 PM
Can't get tach to function using MSD 8920 Tach Adapter.
Car is 70 Firebird non gauge equipped originally. I am running an MSD pro billet dist, MSD 6A box, and MSD coil. I installed a factory tach from a later year Trans Am (76 I think) and have the portion of the factory tach harness that plugs into the tach. It appears to use stand alone tach wiring as it has its own harness.
Original harness appears to be a 2 wire setup where one wire was 12V and the other wire went to the neg side of the coil. Research says the light colored wire was 12V and dark to the -coil. Does anyone know if the tach itself has to be well grounded?
I hooked up the tach adapter using the instructions for the voltage triggered tach and got no tach movement. Double checked connections as well as power and adapter ground with no results.
Tried changing the connections of the adapter for current triggered tach. same results and doublechecked.
Am I using the wrong tach adapter? (summit guys thought this would be the best one to use). Is there a housing ground for the tach I didn't know about? Is there a way to test the tach using the orig harness to verify that it should work without disassembling the dash and removing it or taking the car out of the garage? If I could I'd park a car with stock ignition next to it and make some long jumper wires to check it but thats not practical where the car is.
Thanks John
Thanks John
