View Full Version : Photos of Laguna 22 Dec
CurtiSS 69
01-25-2008, 02:43 PM
Hello Folks,
Better late than never:
Regards
CurtiSS 69 "The Rainmaker"
buickfunnycar.com
01-25-2008, 03:10 PM
Look at Mary go...
Orngcrush69
01-26-2008, 05:52 PM
#117 Thanks you for the picture...I'm think'in more front spring rate, what do you guys think?
CurtiSS 69
01-28-2008, 03:36 PM
Dave,
Is it a concern about the amount of body roll in the photo, or is there a handling problem? Remember that Turn 5 is banked and it will make the body roll look worse. What front spring rate are you running now? If you have stiffer springs try them and compare. Only you will be able to decide if they are better, as it is a driver preference issue for track schools.
Photos can be very useful for finding problems. This is how I found that the anti roll bar links came loose last year. Some video showed the car roll and then stop. I traced it to the anti roll bar links.
Regards
CurtiSS 69
Orngcrush69
01-30-2008, 06:36 PM
We're running Afco 650lbs in the front, we have a set of 700's I might change up to them next time out.
CurtiSS 69
01-31-2008, 12:09 AM
Dave,
That's less than an 8% change. Do you think it will make that much difference?
Regards
CurtiSS 69
Orngcrush69
01-31-2008, 08:53 PM
Your guess is as good as mine. This whole project has been a try and see, with good results...so won't know till we try them.
