View Full Version : confussed newbie (first gen rear)
woodstock
01-21-2008, 12:30 PM
i have done alot of serches and im kinda confussed, i have a 67 camaro, im looking to put rear dics on it. alot of ppl are saying how everything gm is interchangeable (somewhat), Is there parts i can order through NAPA that will bolt to my rearend, i have tryed talking to ppl around here but no one knows anything, any help will be great.
i hear 79-81 trans am rotors will work but what backingplates and calipers? anything still available?
thanks guys
01-21-2008, 04:13 PM
You can use 98-02 Camaro/Firebird brakes.
Very easy swap. Not too bad price wise if you keep your eyes open. I picked up a complete rear set set for $200.
You will need the backing plate parking brake assembly,cables, calipers and rotors. You will need a 1/8" spacer to go between the backing plate and rear end housing. OR cut that section out of your old drum backing plate.
15" rims will not work.
You can use the earlier stuff but the calipers are prone to leaking.
derekf
01-22-2008, 04:18 AM
I hadn't heard about the 1/8" spacer. Is that with all the LSx era Camaro rear disk setups going on pretty much anything?
69keith
01-22-2008, 06:03 AM
you have to use the spacer to center the caliper bracket with the rotor
woodstock
01-22-2008, 12:23 PM
200$ for everything, is that from a wrecker?
69keith
01-23-2008, 05:21 AM
I bought mine from a swap meet $125 - backing plate to caliper
nicks67camaro
01-23-2008, 05:45 AM
Does this upgrade require longer wheel studs as well?
Taylor1969
01-25-2008, 08:22 PM
It is a good idea... the rotors are quite a bit thicker then the drum... and aluminum wheels have a bigger seat then original steelies as well.
pdq67
02-08-2008, 02:52 PM
Have you been over to Team Camaro yet and done a search?
I have 1988 'Vette 13" front rotors w/ big 1/4" wider single piston calipers on homemade brackets on 2-piece hubs and disc brake forged spindles on the front and the rear has 1989 Camaro 11.75" rear rotors w/ 1980 Cad. Seville e-brake calipers on homemade brackets on my 12-bolt.
It's my CHEAP, "pdqCBB" setup!
And it take's 17" rims....
pdq67
neki67
02-08-2008, 11:54 PM
http://www.geocities.com/torkerscamaro/torker.html
