View Full Version : Need some brake advice
Wagonboy
01-21-2008, 10:47 AM
Well I am building a 1964 chevelle 2dr wagon, and I am starting to get things together for the chassis. I am running ART A-Arms and ART trailing arms, on a stock boxed frame. I want to do a 4 corner big disc brake set up. I dont need 6 piston calipers, since it will be a driver/show car. By NO means am I trying to build this thing cheaply, but I like to stay realistic with my budget. My pocket isn't nearly as deep as some of the folks on this site with these sick sick cars..(my jealousy is seeping through)..lol So I am just trying to see what others think about the kits on the market, and what they favor. I have looked a little into Wilwood, and SSBC. Are there other comparable companies out there that wont "brake" my budget?..lol
T
ProdigyCustoms
01-21-2008, 12:08 PM
We have the following kit for your Chevelle and have no problem fitting you components.
Prodigy Customs introduces our Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
Kits include:
Wilwood Parts Include:
Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Prodigy Customs Parts Include:
Front Braided Brake Hoses
Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
NOTE:
($1750 Kit includes BLACK CALIPERS and NON Drilled / Slotted Rotors)
Options include:
Red, Blue, Yellow, Silver and Polished Calipers are A + $200 Option,
Drilled and Slotted Rotors are a + $200 Option
Wilwood Aluminum Dual Reservoir Master Cylinder is a + $170 Option
Dual Diaphram Polished Stainless Power brake Booster $200
KIT AS SHOWN WITH RED CALIPERS, DRILLED AND SLOTTED ROTORS, AND POWER BOOSTER IS $2350.
Wagonboy
01-21-2008, 01:32 PM
Im liking that kit, I have been reading some of the nightmare stories about the drilled rotors. Do you have just slotted rotors?? and are the polished calipers powdercoated clear?? or any kind of dull/fade protection.
01-21-2008, 01:55 PM
Don't worry about the stories since your car is a driver show car. They will look great on there.
Now if you had a driver/track car then i'd worry. Note, we have run the "quality" drilled and slotted hard with no problems.
Wagonboy
01-21-2008, 02:35 PM
Im guessing that the wilwood rotors are classified as "quality" opposed to the ebay rotors for $19.95...LOL
ProdigyCustoms
01-21-2008, 04:05 PM
MrQuick is correct, you are in no danger of hurting drilled and slotted rotors. the polished calipers are not powder coated, so they give you plenty to do if you like maintaining things!
Wagonboy
01-21-2008, 04:42 PM
Its not that I like to maintain stuff, I am just trying to make it as clean as possible, and still see the caliper. The red and yellow ones are far to "sport compact" and the black is to subtle. So if the polished is just that with no protection, I may just go with silver, since the rest of the suspension will be silver and shades of gray.
ProdigyCustoms
01-21-2008, 07:01 PM
Silver is super hot. Here is a blue set we installed yesterday on one of our builds. The car is back with blue stripes and is going to be very cool with these blue brakes
Wagonboy
01-21-2008, 07:23 PM
super hot as in?? hot cool or hot like burning up
