View Full Version : Anyone running 295/35/18 on a 10" rim?
staged67gspwr
01-18-2008, 06:02 AM
Is it possible to measure across to tell me how wide over all the tire is from edge to edge?
comp-spec
01-18-2008, 07:34 AM
Check this site it will give you all that info ........its 11.6
http://www.rims-n-tires.com/rt_specs.jsp
staged67gspwr
01-18-2008, 07:41 AM
Thank you sir.
fast Ed
01-18-2008, 08:11 AM
It's going to depend on what brand and model of tire you're using. Size varies a lot between the manufacturers.
cheers
Ed N.
comp-spec
01-18-2008, 08:30 AM
Thats true they are not all the same. Different brands do varie
staged67gspwr
01-18-2008, 08:32 AM
Well here`s the deal,im trying to fit a 295 under there but my wheel well from the frame to the lip which is bent up already is 12" you think i can get away with the 295?i would go 285 35 18 but cant seem to find a tire i like in that size?
