View Full Version : Schwartz 1st gen Camaro full frame weights
jeff s
01-16-2008, 09:20 AM
I had the chance to get some weight data together on our Schwartz Camaro Full Chassis for 1st generation F Body.
I'd also like to mention the side port for exhaust is an option, we can do the chassis without that.
Weight assembled with 20x12.5 and 19x9 forgelines, michelin pilot PS2, 335/30x20 and 255/35x19 14" front and 13" rear non drilled rotors, 6 piston fr and 4 piston rr wilwoods, a complete winters 9" with iron Moser 3rd member, axles, power rack etc. is 827#.
Without rear end, wheels, tires, but with the 14" dia non drilled six piston front brakes still on it 334#.
Without brakes, Full frame, includes power rack, spindles, coilover shocks, springs, all nuts, bolts, solid front and rear sway bars, steel braided brake lines, and steel hard lines, all fittings, fully powdercoated. 276#
Measured with calibrated Intercomp digital scales.
A stock subframe with sway bar is about 350#
andrewb70
01-16-2008, 11:44 AM
Here is the Schwartz Extreme Performance full frame chassis:
Overview from the top:
https://www.pro-touring.com/~andrewb/schwartz/first_gen_chassis_top_view.jpg
Front suspension detail:
https://www.pro-touring.com/~andrewb/schwartz/first_gen_chassis_front_01.jpg
Front brakes detail:
https://www.pro-touring.com/~andrewb/schwartz/first_gen_chassis_front.jpg
Rear suspension detail:
https://www.pro-touring.com/~andrewb/schwartz/first_gen_chassis_rear_01.jpg
Rear ends feature full floating hubs:
https://www.pro-touring.com/~andrewb/schwartz/first_gen_chassis_rear_floa.jpg
LONE*STAR
01-16-2008, 12:29 PM
my wallet hurts........any idea on price....complete -wheels?
frankenstang
01-16-2008, 04:57 PM
Call jeff at the shop. You will be surprised at how competitive the prices are.
Forgelines are expensive from ANYBODY! I've priced them out and... NOT!
Kenova
01-16-2008, 05:14 PM
I'm curious as to what, if any, modifications need to be made to the floor pan.
The full frame looks like it would add more rigidity than just a set of sub frame connectors.
Ken
deuce
01-16-2008, 07:11 PM
no floor pan mods needed , this will bolt on and pretty much have little cutting to body . ( info from jeff s himself )
frankenstang
01-17-2008, 09:00 AM
Only cutting needed is to min-tub the rear. There are also connector bars from the firewall to the front shock hoops available. The frame is pre drilled for the bars and you would have to make mounts for the firewall.
jeff s
01-17-2008, 08:48 PM
Mini tubbing to fit the chassis is not required. Of course if you're going that far, might as well fit fat tires. Bare chassis is $3495.
Email me for detailed price list.
