OLDFLM
01-08-2008, 05:46 AM
Hello Everyone!
Hope the Holidays have treated you and yours well…
Just some thoughts on my “to do” list for my 71 Firebird and direction on where I think I want to go with it… let me know what you think…
I got some cash for a new dash pad for Christmas and I hope to do my Autometer gauges next week.
I’ve also got new weather stripping for the car… I just have a bunch of little projects I need to do:
- Vinyl dye kick panels (they’re already black but I cleaned the rears and shot them with SEM Landau Black and they look brand new!)
- Paint interior pillars and window top trim
- Repaint grills/ram air openings in my Formula hood (just to freshen them up)
- New Formula emblems
- New outer window felts
- New doors sills
- New carpet
- Battery hold down & tray
- 3-point Morris concepts retractable seatbelts
- 12” b-body spindle/1LE swap (may also add hydroboost as my car was a factory manual disc/drum car)
- Change speedo gear to match 3.42s in rear
- 12.7 to 1 steering box
- Poly body bushings
Once all that’s done I’ll start looking at a cheap 18” wheel/tire combo so that I can run the C6/Z51 brake kit. Just want to visually fill those big wheel wells. I’ve been thinking that since I almost bought a new C6/Z51 Corvette that I’d try to go with C6 sized wheels/tires and brakes on my bird. C6 wheels/tires are 245/40/18 front and 285/35/19 rear… I’m thinking of taking those specs 10mm wider front and rear though… I’m pretty sure they’ll fit without issue.
SWs red 73 TA had 255/40/18s (4.5bs) and 295/35/18s (5.5bs) on 18x8f & 18x10r TTIIs without any mods to the car and they didn’t rub. But then again I like to run a taller tire with more sidewall… I guess I could run a 295/35/19 out back and have the same sidewall as the 255/40 up front… that would get me to 26”f & 27” rear diameters. But a 45-series on the 18s would get me to 27”front and 28.5” rear and would probably work better when street driven too. Rim choice is tough though… any thoughts? I’ve been looking at TTIIs, Bonspeed and Budnick… etc. I can get 18/19 Cannons with tires for around $2900.
I’d also like to install a vintage air system to make driving the car in the summer down here in Georgia more enjoyable.
Just want a straight forward driver that looks mean.
To that extent I’ve been thinking about a 4-speed auto for the car too… just need to find an inexpensive 2004r & 2500-ish stall.
To give my car some direction my thoughts are that I want C6/Z51 performance and braking…
The C6 specs are 400hp/400lbft, 0-60 in 3.9 seconds, 60-0 in 125ft and ¼ mile in 12.4 @ 116mph.
Too get my heavier 'bird to run those numbers though I’ll need 500hp (100+ more). The C6 has 7.94lbs/hp and at 500hp my car would have 7.6lbs/hp.
I initially started out thinking of C6 Z06 specs (0-60 in 3.7, 60-0 in 108ft and ¼ mile in 11.3 @ 125) but that would take way more hp (600) and much bigger brakes than my budget would allow… even then I don’t think that I can get it to stop 60-0 in under 108ft! But I think 60-0 in under 125ft is doable. We’ll see. I may even try to attain that performance with my stock Rally IIs… might be more fun/interesting that way IF I can do it.
What do you think?
Let me know your thoughts/suggestions...
V/R,
Ty
- New doors sills
- New carpet
What do you think?
V/R,
Ty
