View Full Version : 69' Camaro, 00' Trans Am WS6 Disc Brakes
willih6996
01-07-2008, 05:07 PM
Just wanted to know if there is a conversion kit of some sort to put 00' Trans Am WS6 front and rear disc brakes on a 69' Camaro with drum brakes all around. The rear in the 69 is an 8.5" 10 bolt. Appreciate all the input possible. Thanks
Project69
01-07-2008, 05:19 PM
Kore industries makes a kit i think.
willih6996
01-07-2008, 05:23 PM
Thank you. I'll check it out.
willih6996
01-07-2008, 05:25 PM
Do you happen to have there web site?
willih6996
01-07-2008, 05:31 PM
Thanks. Found it.
Memphis
01-07-2008, 08:06 PM
found it i believe
http://www.kore3.com/
Memphis
01-07-2008, 08:10 PM
I forgot I had this site bookmarked should help you with the rear
http://brphotrods.com/Rear%20Brake%20kit.html
zman1969
01-10-2008, 01:19 PM
I carry brackets to mount the LS1 calipers and rotors for a first gen. 55$ a set shipped. relatively simple , cheap i did my own with a 4 1/2" grinder and a drum brake lathe to turn down drum brake hub 16" wheels needed David Pozzi's website has a thread about the swap PM me if you need more info , heres pic of the brackets:
https://static1.pt-content.com/images/pt/2008/01/ls1brkt2-1.jpg
zcrz
01-10-2008, 05:31 PM
anyone know if a drum hub will fit disc spindles?
willih6996
01-10-2008, 05:46 PM
Thanks Memphis. Good Link
willih6996
01-10-2008, 06:08 PM
Thanks ZMAN1969. I sent you another question about your brackets. Thanks again.
Hammered
01-10-2008, 06:27 PM
Yes, I just did this swap: https://www.pro-touring.com/forum/showthread.php?t=38128
I have an extra set of front bracket blanks you could finish machining for a disc spindle.
Taylor1969
01-10-2008, 08:51 PM
the BRP Hotrods link above has the full setup. He will even swap the correct hubs with you.
zman1969
01-11-2008, 07:42 AM
yes they will only difference is the upper mounting boss depth for caliper bracket or backing plate
