View Full Version : What type of gasket for 9 inch?
CamaroJesse
01-07-2008, 01:37 PM
I think i need to use rtv possibly. If so, which type do i use? this is for the third member gasket.
thanks
chicane67
01-13-2008, 03:11 AM
No gasket... just RTV...
01-13-2008, 11:34 AM
make sure its a sealer for gear oil. Mopar makes a great grey RTV that seals real nice. I believe Ford and GM do too.
OHCbird
01-13-2008, 08:16 PM
Permatex 'Ultra Gray' is used by many shops I know. I put it on my old 89 4 runner @ 275K miles, and when I sold it @370K miles, it still hadn't leaked (yes, of course I changed it).
powerjames
01-14-2008, 12:31 PM
I'd suggest the Ultra High Temp stuff.
Yelcamino
01-14-2008, 03:49 PM
You could also try a gasket from Lubelocker. It's a steel shim gasket with a special coating. I have one on each of my cars and they work great.
http://www.lubelocker.com/
parsonsj
05-25-2009, 02:33 PM
Lubelocker looks like the answer to me. I'll look into that tomorrow.
Related question: Anybody got an install tip for the studs? It seems to me that I had seepage past the studs that hold the 3rd member on. I knocked the studs back out to clean up the mess of a gasket I used last time (which worked fine), but I'm wondering what you guys think about using some permatex on the spline area of the studs.
jp
Yelcamino
05-25-2009, 04:11 PM
jp
Maybe you could try some red loc-tite. Remember those hamonic damper repair kits that used a ultra thin steel tube that slid over the hub of the damper so the timing cover seal would have a new surface to seal on? A little tube of red loc-tite came in the kit to hold it in place and to seal it.
jpdeuce
05-25-2009, 04:33 PM
Most any of the grey rtvs will work great for oil/gear oils.
parsonsj
05-25-2009, 06:21 PM
I was thinking of loc-tite too. Seems like it's worth a try.
I've done black RTV, and I've done a gasket. The gasket worked better, since the RTV method leaked, but it was hell to get off the housing. It bonded with the housing so tightly I had to sand it off.
I'm hoping this lube-locker product will work better.
jp
big gear head
05-26-2009, 06:16 AM
The studs all leak. That's why Ford put the copper washers behind the nuts. The washers stopped the leaks.
parsonsj
05-26-2009, 08:12 AM
The studs all leak. That's why Ford put the copper washers behind the nuts. The washers stopped the leaks.I'm learning, I'm learning! Since my stuff is all aftermarket, I didn't know to use the OEM copper washers. Anybody got a source for 10 of 'em?
jp
parsonsj
05-26-2009, 08:24 AM
I picked up the last Lubelocker gasket in Orlando just now. The local speed shop is pretty frustrated with Lubelocker. I guess they've been on backorder for a long time...
jp
big gear head
05-26-2009, 08:45 AM
I don't use the washers. I just put some RTV on the back of the nut before I put it on.
