View Full Version : 20x10 1st gen offset
LONE*STAR
01-03-2008, 11:25 AM
will a 20x10 wheel for a Bmw with a 35+ offset work w/ fender lips rolled without wheel tubs on a 1st gen firebird? if so what tire? thanks!
DriverzInc
01-03-2008, 11:28 AM
That is a 6.875" backspace on a 10" wheel, you need somthing more along the lines of a 5.5-5.75" backspace, so you'll need a spacer.
As far as tire, a 285/30/20 is a safe way to go.
ProdigyCustoms
01-03-2008, 12:04 PM
Remember a Firebird has a "Wide track" 1" wider rear then a Camaro. Since we normally set up Firebirds with 6.5" backspace, you are a maybe within a 1/8",
LONE*STAR
01-03-2008, 12:54 PM
thanks so......since im looking for 20x10's on ebay under bmw wheels they are usually given in mm offsets what range should stay within? thanks guys
01somta
01-03-2008, 04:29 PM
1" = 25.4mm
ProdigyCustoms
01-03-2008, 04:53 PM
Correct
LONE*STAR
01-03-2008, 06:57 PM
so a +25 to +30 mm offset would be good on 20x10" rim?
ProdigyCustoms
01-03-2008, 07:36 PM
That should be very close. If you want to be completely safe you may want to measure you rear end axle flange to axle flange. Make sure nothing has been changed. It should be 61"
DriverzInc
01-03-2008, 09:55 PM
Totally overlooked that, I read first gen, and immediately thought camaro. Good catch... like Frank says, your damn close then, but like he said, confirm your overall length first. :drive1:
