View Full Version : 1951 chevy truck
UK-Mustang
01-01-2008, 02:10 AM
the truck is called a half ton, its a SWB, very popularmaking it very easy and cheap to get bits for. Unfortunatly shippings a bitch!
I started stripping her out, very simple, two bolts broke, and everything went to be blasted and zinc primed so it can go into storage until I need it.
https://static1.pt-content.com/images/pt/2008/01/truck1-1.jpg
is how it started, engine and box missing all standard.
https://static1.pt-content.com/images/pt/2008/01/truck5-1.jpg
https://static1.pt-content.com/images/pt/2008/01/truck6-1.jpg
https://static1.pt-content.com/images/pt/2008/01/ns-1.jpg
https://static1.pt-content.com/images/pt/2008/01/interior-1.jpg
https://static1.pt-content.com/images/pt/2008/01/bed-1.jpg
then I stripped it out, found minor rust, not bad for a 53 year old truck.
https://static1.pt-content.com/images/pt/2008/01/truck4-1.jpg
https://static1.pt-content.com/images/pt/2008/01/truck3-1.jpg
https://static1.pt-content.com/images/pt/2008/01/truck2-1.jpg
Next I decided to start with the rear axel, I got some mono leaf springs from a mate and a Trans am LSD axel from another. I had to make some axel mounts so the TA axel would fit. getting the old ones off was a bitch, but thankfully my wife bought me a 9inch angle grinder for Xmas - problem solved!!
Next problem is the 3 inch U bolts needed to secure the axel are too long so I'm having some made from 12mm bar, then at least I can get her back on the wheels and see just how low it's going to be.
https://static1.pt-content.com/images/pt/2008/01/axelbrackets-1.jpg
Evolution af an Axel bracket.
UK-Mustang
01-01-2008, 02:13 AM
https://static1.pt-content.com/images/pt/2008/01/rearaxel-1.jpg
https://static1.pt-content.com/images/pt/2008/01/axelmocked-1.jpg
https://static1.pt-content.com/images/pt/2008/01/axel1-1.jpg
https://static1.pt-content.com/images/pt/2008/01/longbolts-1.jpg
I could have been rolling again if it was not for this ****-up.
Quick preview of the wheels, these are the fronts, they're 18's on 225's. the backs are 20's on 245's
https://static1.pt-content.com/images/pt/2008/01/18s-1.jpg
350 / 5700cc chevy engine all machined up ready to go, all it needs is a good clean. Yes, that's going t o be the trucks colour!
https://static1.pt-content.com/images/pt/2008/01/350engine-1.jpg
I got the 4 U bolts to hold the rear axel in and got it all bolted down. Put the rear wheels on and let her roll again.
Think I might have got carried away with the lowering! Probably going to C notch the chassis for clearence now.
https://static1.pt-content.com/images/pt/2008/01/rearsuspension2-1.jpg
https://static1.pt-content.com/images/pt/2008/01/rearsuspension1-1.jpg
So I moved onto the front suspension. Dead easy, five bolts and she was off! Nice simple frame, just need to add on the custom made Jag cross member now.
https://static1.pt-content.com/images/pt/2008/01/frontchassis-1.jpg
Got to remove the leaf spring perches, gearbox X member and box the chassis too.
UK-Mustang
01-01-2008, 02:14 AM
Been a little busy making a jig to duplicate the geometry of a XJ Jag, I figure it's a big car, PS, 4 pot calipers, vented disks - just what I needed really.
In reality it's a fookin ugly subframe, not to mention hard to find in good condition!
The one I got was holed, I could have welded it up but what's the point?
So I got some 80x40 and set to, made some guide tubes and this is what you get!
Next to do is make some mounts so the rack mounting points can be taken.
Just waiting for those tubes to be made.
https://static1.pt-content.com/images/pt/2008/01/jig2-1.jpg
That's the drivers side, note the rust.
https://static1.pt-content.com/images/pt/2008/01/jig1-1.jpg
https://static1.pt-content.com/images/pt/2008/01/jig3-1.jpg
Not very interesting but I'll show the mistakes too! but hopefully there won't be too many of those.
got a band saw today so if I can get some 4mm plate tomorrow i'll start making the boxing plates for the rear chassis and getting on some more.
UK-Mustang
01-01-2008, 02:15 AM
https://static1.pt-content.com/images/pt/2007/10/jiggy-1.jpg
suspension jig all done, now I need to have the box section at work cut down and drill some holes for the lower tubes.
https://static1.pt-content.com/images/pt/2008/01/jiggy2-1.jpg
Steering rack mounting jig. Should give me Jag geometry and decent ride quality.
UK-Mustang
01-01-2008, 02:17 AM
I had the chassis boxed with 4mm plate going back under the cab. I figure if the boxing goes as far as the bask of the gearbox uj it should be fine.
https://static1.pt-content.com/images/pt/2008/01/fullyboxed-1.jpg
Then I went back to the x-member and made the rack mounts and teh jig for them, all simple stuff and easy enough to make if you have a band saw.
https://static1.pt-content.com/images/pt/2008/01/rackmounts-1.jpg
Next I noticed that the x-member would not sit flush to the bottom of the chassis and the lower outer corner would foul the A arm. I cut a notch in the box section and profiled the ends and welded them over.
https://static1.pt-content.com/images/pt/2008/01/notching-1.jpg
Then I mocked the memeber into the chassis and it fits spot on. the string shows the centerline of the wheels so I'll get a mate to check my work and then tack the member into place and start into the upper mounts.
https://static1.pt-content.com/images/pt/2008/01/xmember02-1.jpg
Should be nice and strong as you can see the chassis sitting 20mm into the box section.
UK-Mustang
01-01-2008, 02:19 AM
https://static1.pt-content.com/images/pt/2008/01/Picture019-1.jpg
One mock up engine in position and looking rather lost.
https://static1.pt-content.com/images/pt/2008/01/Picture018-1.jpg
As you can see I got it in without cutting anything and it's rather tight!
https://static1.pt-content.com/images/pt/2008/01/Picture015-1.jpg
Gearbox mopounted using a TRUCK SHOP X member, wish I had noticed that it lined up with one hole, would have positioned the engine where I needed it and saved hours of fun!
https://static1.pt-content.com/images/pt/2008/01/Picture013-1.jpg
Once I had it level side to side and front to rear I made some mounts up using some 40mm flat bar and some tube. Trouble was, once the engine was centeral the mounts are offset which threw me for a while.
https://static1.pt-content.com/images/pt/2008/01/Picture012-1.jpg
https://static1.pt-content.com/images/pt/2008/01/Picture014-1.jpg
Steering is a pain, it ocupies the same area as the headers, neither Block Huggers, Camaro or std ones would fit so aR$e is sorting me out with some stainless bends and I'm making my own.
https://static1.pt-content.com/images/pt/2008/01/Picture020-1.jpg
Header flange in 6mm, I have the same but in 10mm, unfortunatly even thay need machining to clear a lump on the heads!
There you go, header building next!
UK-Mustang
01-01-2008, 02:22 AM
Just been having a quick play, shock mounts being made, x member tube ordered, so it's a quick jolly in to the exhaust headers.
Problem is the steering interfears with the exhaust, I've tried every set I can borrow and they are all crap, only choice is to make my own!
10mm flanges bought from www.popbrowns.co.uk (http://www.popbrowns.co.uk) made from stainless steel and modified slightly as they hit a screw in plug.
https://static1.pt-content.com/images/pt/2008/01/100_2010-1.jpg
next I went to B&Q/home depot and got some 15mm copper pipe and some foam insulation - it just happens to be the same diameter as the header pipes!
A mate got me a load of stainless bends and about 18ft of pipe (cheers mate!) and gave me a few pointers too!
https://static1.pt-content.com/images/pt/2008/01/100_2011-1.jpg
I found an old cosworth bottom pulley was the same diameter as the bends so I used that to bend the pipe. :banana:
Once I had trial fitted the copper pipe I insulated it and tried it again.
https://static1.pt-content.com/images/pt/2008/01/100_2012-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2013-1.jpg
Sweet! :top:
I cut the bends on a chop saw and a band saw and TIG tacked them together.
And whey hey! she fits
https://static1.pt-content.com/images/pt/2008/01/100_2015-1.jpg
All I have to do now is 7 more and the collectors! :cry:
UK-Mustang
01-01-2008, 02:24 AM
I've been tormenting myself with the headers and ended up with this-
https://static1.pt-content.com/images/pt/2008/01/100_2182-1.jpg
They miss the steering , chassis don't drop too low either - I'm impressed!!
Once you 'see' how it's all working it's not too bad, it just ppissed me off for weeks and I had to walk away.
https://static1.pt-content.com/images/pt/2008/01/100_2181-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2180-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2184-1.jpg
I also got round to mounting the rear air bags and antio roll bar (rover 420 - one use at least!)
Avo adjustable shocks.
https://static1.pt-content.com/images/pt/2008/01/100_2189-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2188-1.jpg
Interior wise, I've repaired the seat base and sent the seat to be trimmed
https://static1.pt-content.com/images/pt/2008/01/100_2187-1.jpg
Installed the air ride mounting plate and smoothed the dash where some bits had been mounted
https://static1.pt-content.com/images/pt/2008/01/100_2191-1.jpg
Also made some steering column brackets from alloy
https://static1.pt-content.com/images/pt/2008/01/100_2186-1.jpg
UK-Mustang
01-01-2008, 02:30 AM
started into some rust repair of the floor, Loads of bodged up panels welded in with gas, chopped them all out. Could just bodge paltes in but I figure to do it right means I'll do it once.
so....
Chop crap out
https://static1.pt-content.com/images/pt/2008/01/100_2727-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2728-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2729-1.jpg
make repair panel as no fooker wants to answwerr the phone or emails regarding repair panels.
Thank god I bought a bead roller, shear and folder.....
https://static1.pt-content.com/images/pt/2008/01/100_2731-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2733-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2732-1.jpg
New rear wings ordered as well as brake servo kit.
J2speedandcustom
01-01-2008, 09:16 AM
Sweet truck build! Keep the pics and updates coming. :cheers:
UK-Mustang
01-01-2008, 10:23 AM
I've been on it a few years as you can tell from the dates on the pics.
I just thought i'd show it off on another forum!
at the moment i'm just finishing the frame and parts are off for poweder and plating.
It's taken me 6 months to get my Mustang back together, if I need the smallest part it takes 3 weeks to arrive, and it's always been stupid stuff!
then large parts can only be shipped cheaply once a year when a friend brings two cars back, other parts collected on visits to the U.S.A, so it's not quick and easy!
still, back to the truck!:twothumbs
UK-Mustang
01-01-2008, 10:28 AM
done some repair work to the cab floors, sorry for the angle, the cab is on it's fire wall.
https://static1.pt-content.com/images/pt/2008/01/100_2867-1.jpg
repair to the OS corner, decent sized access panel made for the gearbox, even though there is little you could do. I figure it's batter to have it and not need it than the other way round :DD:
The tunnel now unbolts,
https://static1.pt-content.com/images/pt/2008/01/100_2862-1.jpg
running out of space here...
New rear arches arrived in the meantime -$700 the pair vs £700 if I buy them in the UK, thankfully a mate was shipping a container so they hitched a lift!
Thank god for a decent exchange rate, they came in at £400
https://static1.pt-content.com/images/pt/2008/01/100_2864-1.jpg
So still in need of some repair panels, I go on holiday to Florida where I pick up two cab corners for $35 each, way too cheap to even bother making them!
Cut off the rot, repair the inner section, slap on some primer.
https://static1.pt-content.com/images/pt/2008/01/100_2865-1.jpg
Trial fit the outer section.
https://static1.pt-content.com/images/pt/2008/01/100_2863-1.jpg
UK-Mustang
01-01-2008, 10:33 AM
Got the drivers side lower corner on with all the welds ground off. came out pretty well for a repair panel
https://static1.pt-content.com/images/pt/2008/01/100_2879-1.jpg
So I then started on the passenger side, pretty rank but as I spent years doing Beetles up, this is nothing
Bloody amatures used news paper and filler....
https://static1.pt-content.com/images/pt/2008/01/100_2881-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2882-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2880-1.jpg
Chopped out all of the crap, made the inner section using rollers.
https://static1.pt-content.com/images/pt/2008/01/100_2889-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2890-1.jpg
Must say the metal on this cab is in very good condition, cleans up very well and welds superb with no blowing out.
Using Frost welding clamps (very handy!) corner is positioned, This corner was a problem, the panel flattened out noticably when it was cut. Used a couple of the clamps to pull it back into shape.
https://static1.pt-content.com/images/pt/2008/01/100_2891-1.jpg
Next I moved onto positioning the master cylinder mount. Originally this was a single circuit system - no good with the uprated brakes i'm using. So I purchased a MC and servo kit from the states.
Very well made, but should mount inside the chassis rail.
Before-
https://static1.pt-content.com/images/pt/2008/01/100_2883-1.jpg
After a visit from the 9 inch grinder -
https://static1.pt-content.com/images/pt/2008/01/100_2895-1.jpg
Also clamped to the chassis rail where I beleive it would be, weld that on sometime....
Next problem area was the front lower corner of the passenger A piller - it was missing!!
Out with the cutters, grinders, cardboard for templates and two hours later - 90% of the corner is there!!
https://static1.pt-content.com/images/pt/2008/01/100_2892-1.jpg
https://static1.pt-content.com/images/pt/2008/01/100_2893-1.jpg
Cab then went to be blasted, came back in good condition with some minor perforation on some double skinned sections.
engine is to long block stage
new truck bed arrived.
brake fittings and some minor parts too.
Calipers off for a rebuild and paint
gearbox is away for a rebuild and shift kit.
UK-Mustang
01-01-2008, 10:42 AM
https://static1.pt-content.com/images/pt/2008/01/100_2940-1.jpg
front subfrome is done and mocked up. jag anti roll bar and Ford/Mercury Capri ARB's
LHD rack posted from the states, thank you ebay!!
I'm currantly in the process of installing a K member to strengthen the whole lot up, as well as a propshaft hoop.
https://static1.pt-content.com/images/pt/2008/01/truck002-1.jpg
will have to reposition the air tank and pump as I got carried away.
The problem i'm haveing is over the xmas break, anyone I need to see to get supplies etc is shut!
Bolt on chassis components are off being poweder coated, nuts/bolts etc will be taken for zinc plating.
Axel is being scrubbed clean ready for some paint
https://static1.pt-content.com/images/pt/2008/01/truck001-1.jpg
Unfortunatly I painted it and then realised i'd forgotten to weld anti tramp bars onto it. Bugger....
the front x mamber was looking very bulky and agricultural. Gave that some with a grinder and now there is extra clearance for the front pulley etc.
https://static1.pt-content.com/images/pt/2008/01/truck003-1.jpg
hopefully next pictures will be of a fully painted chassis with stuff going onto it.
can't wait!
thanks for looking, I apologise for the crappy pictures, that camera is now gone. Please be aware, this is my 1st major project, i've done VW's before but felt it was time to get into something with some balls.
nekkidhillbilly
01-02-2008, 12:02 AM
not a fan of the wheels but sweet truck none the less
brrymnvette
01-02-2008, 11:07 AM
100% agree.
Benoit23
01-02-2008, 12:00 PM
I have a 1955 1st series Chevy (see sig) that I’m trying to sell & looking at your build pics make me want to keep the old truck.
Looking good man keep the progress pics coming!
Chris
jaybee
01-02-2008, 01:44 PM
That'll be nice. My wife would like my next project (assuming I ever finish this one) to be a pickup. I agree completely if it can be like yours.
scogin918
01-03-2008, 04:56 AM
To be honest, I kind of like the wheels. It will give the truck a West Coast feel and that's not always a bad thing. There are some very clean and simple Impalas along with some other cars that roll with wire wheels without being over the top Lowriders.
By the way, where in the UK are you. It wouldn't happen to be in the Northern part would it? Glory, Glory Man United as the Reds go marching on, on ,on!
UK-Mustang
01-03-2008, 12:12 PM
I like the wheels, they are completely nuts!
everyone does alloys/5 spokes etc but damn are they heavy!
I found these pictures from a little while ago (april)
I mocked up the front wing just to see how much trouble i'm in
https://static1.pt-content.com/images/pt/2008/01/100_2448-1.jpg
loads I think! no truning on full drop.....
https://static1.pt-content.com/images/pt/2008/01/100_2447-1.jpg
the bumper should rest on the ground at full drop.
will have to rise the front by 6 inches before I can turn the wheel.
It'll be fun if anything!
Benoit23
01-03-2008, 12:58 PM
If you like the wheels, that's all that counts.....Do what you want, it's your truck. I thought about putting spokes on my old truck, I like'em.
Chris
These are the wheels I wanted to put on my truck (the rims on the car).
https://static1.pt-content.com/images/pt/2008/01/youdreamit-1.jpg
jeff s
01-03-2008, 10:13 PM
You know we have a bolt in Schwartz Pro-touring chassis for those 49-54 Chevy trucks.
With our racing style swaybars and spherical rod end suspension.
www.gmachinechassis.com
UK-Mustang
01-03-2008, 10:42 PM
www.gmachinechassis.com (http://www.gmachinechassis.com)
The problem we have in the UK is the cost of items 'landed'
it's quite often, once shipping, handling, import and sales tax have been added, the initial cost can double.
import tax could be 4% as a spare part, or maybe 22% if they class it as a comercial truck, sales tax on top of everything is 17.5%
importing a built car can work ok at todays exchange rate
for parts shopping it's better to come on holiday and abuse the luggage allowance or get a container, ship 2 cars and pack it full.
nice chassis though!!
