prozoo
12-31-2007, 09:15 PM
I would like to know if a rear end out of a 74 Camaro will fit my 67 Camaro. What would I need to look for and measure to fit this rear end into my car.
zman1969
01-18-2008, 10:33 AM
the 74 is 1" total wider than the 67 rear end and the perches are moved farther out so its NOT a bolt in. a 72-78 nova 8.5 (watch out 75-78 6 cyl novas have 7.5" rears-AVOID these)will bolt in - keep in mind the 67 has mono springs and most Novas used multi-leaf- or you can install the nova springs in your 67 too. but you could make the camaro rear with repositioning of the spring perches, i would do the nova rear
redfire69
01-18-2008, 10:47 AM
check out the discussion in general drive train...
https://www.pro-touring.com/forum/showthread.php?p=349382
