View Full Version : 3.75" BS on a 9" wheel
69TAPoser
12-29-2007, 01:01 PM
I have a narrower than stock width 9" rearend. I just measured for my wheels using a wheelrite tool and it looks like an 18x9 wheel with a 3.75" bs will center the wheel in the wells.
Has anyone seen a 9" wheel with only 3.75" BS? I want a deep dish, but not too much dish.
Phil
ProdigyCustoms
12-29-2007, 03:58 PM
That is going to make a 4 1/2 lip or so, which will look HOTT! What kind of wheels are you doing? Welded 2 piece? 3 peice? A negative offset wheel will work on the wheel bearings a bit, but not to bad at this offset. Big 3.15 Ford bearings would help.
ProdigyCustoms
12-29-2007, 04:01 PM
Just thought of something, How wide is your rear axle flange to axle flange, Where the wheel meets the brake drum / rotor? 57 1/2"?
69TAPoser
12-29-2007, 07:42 PM
Hi Frank-
Yes, it is exactly 57.5". How did you know? It is a Ford 9" (big bearing). Did you think of something in particular?
I am planning on Budnik Fontana's, fat lip, black powder coat centers, brushed lip.
Phil
ProdigyCustoms
12-29-2007, 09:42 PM
Hi Frank-
Phil
Oh, I don;t know, I might have done one or two of these, LOL!
Actually I was able to back into your rear end width based on your backspacing. I have done so many and have some many notes..........
You will be fine with that backspace. If you need any help let me know.
DriverzInc
12-30-2007, 08:52 PM
That's perfect being that Budnik's MIN backspace is 3.75" with a 1" mounting pad. Those will look hot.
ProdigyCustoms
01-03-2008, 09:54 AM
Thanks for your wheel order Phil!
