View Full Version : 1969 Camaro 17" front tire size
vicious69
12-28-2007, 09:08 PM
I'm building a 1969 with DSE Mini Tubs and going to run 17" wheels. I'm running a 315/35/17 on the back but should I go with a 245/45/17 or a 245/40/17 on the front? Don't want to have clearance problems, running stock a arms.
Vicious69 :bananna2:
Project69
12-28-2007, 09:17 PM
Go bigger, im running a 255/40/17 on the front of my 69. It has stock a-arms with a hotchkis 2-1/2 drop. There is no rubbing.
Apogee
12-28-2007, 09:25 PM
Between the two choices listed, I'd run the 245/45R17 as it's going to be the larger of the two diameters at 25.7", versus 24.7" for the lower profile tire. Size will vary depending on wheel width and possibly make/model of the tire so the above specs are only good with the tires mounted on spec wheels for tire sizing.
6'9"Witha69
12-29-2007, 12:40 PM
Go taller with the 45 series. It looks better in the 17" size.
buickfunnycar.com
12-30-2007, 09:34 AM
All agreed...245/45's are a very safe choice and they fill up the wheelwell great.You will not rub...my car is super low as you can see:
https://static1.pt-content.com/images/pt/2007/07/DSC03948-1.jpg
Mr Nick
12-30-2007, 04:21 PM
musclecarjohn... your car is on the cover of the 2008 Flowmaster/US Tire & Exhaust calendar we have at work. Great looking ride!
buickfunnycar.com
12-31-2007, 09:29 AM
Yeah...how about that?That Dave Fetherston is a pretty tricky guy...:naughty:
I got a call from Mary Pozzi in Vegas,she let the cat out of the bag.
I haven't seen the US Tire version...is it different?
vicious69
01-03-2008, 08:55 PM
If I go with the 255/40/17 or 245/45/17 tires what sort of off set would I have to have to not rub and run stock a arms? 17x8 wheel? 17x9 wheel? 17x8.5? which should I run.
:6gears:
6'9"Witha69
01-04-2008, 10:26 AM
I run 17x8 with 4.5" bs 245/45/17.
Neil B
01-04-2008, 02:08 PM
On my car, a 17x8 4.5 BS wheel, 245-45-17 Nitto 555 tire, stock disc brakes, and Hotchkis springs rubs just a bit on the driver's side outer fender with the steering wheel turned full lock to the right. Every car is a little bit different.
https://static1.pt-content.com/images/pt/2007/05/105_0600-1.jpg
buickfunnycar.com
01-04-2008, 03:10 PM
Every car is different indeed.
I would think a 17x8 w/4.75-4.85" b/s on 245/45 rubber would be a very safe combo.
6'9"Witha69
01-04-2008, 10:44 PM
I hit the frame just before full lock. A little modification to the steering arm stops . . .
