View Full Version : 4 wheel discs behind 15" wheels
O'Neall
12-28-2007, 10:38 AM
Does either WIlwood or Baer make 4-wheel disc kit that would fit behind a 15" snowflake 77 Trans Am wheel? I'm pretty sure the 12" rotors are too big... do they make an 11" that would fit?
Skip Fix
12-29-2007, 06:43 AM
12" 1LE rotors and B car spindles do. I think the 10.75 Wilwood kit for the fronts is the next size smaller than 12.19 kit.
radback
01-21-2008, 12:07 AM
What about rear?
I heard Blazer conversion fit under snowflakes.
Is there any other choice for rear?
What about this C4 conversion? (http://www.geocities.com/torkerscamaro/torker.html)
thanks
01-21-2008, 12:51 AM
I know the Dynalite Pro Series will fit behind OEM rims. Give Frank a hollar, he would know for sure about the snowflake fitment.
woody80z28
01-21-2008, 11:42 AM
I did the 12" 1LE on the front and S10-Blazer 11.5" rear on mine to clear the stock 15s. Cheap solution too.
radback
01-21-2008, 01:00 PM
Woody,
do you have a full part list (with part numbers) for the conversions you've made (I've found some lists on the net, but not a really full one) including all the parts needed?
I'm located in france, so I need to buy all parts new from US, and I can't afford to order the wrong parts, so this list would be very helpfull.
Few questions about the Blazer conversion:
-Do you need longer Bolts if you start with a rear drum car?
-Do you need to change the mounting point of the master cylinder rod on the break pedal?
Thanks a lot!
ProdigyCustoms
01-21-2008, 01:56 PM
We have a Wilwood kit with 11.75 front and 12.2 rear that fits.
woody80z28
01-21-2008, 03:58 PM
Woody,
Thanks a lot! Just started this:
http://www.nastyz28.com/forum/showthread.php?p=1054119#post1054119
I used the donor Blazer's bolts and the master cylinder rod should not be a problem.
radback
01-21-2008, 04:59 PM
Thanks Woody.
Aren't the Blazer studs metric?
I suppose drum axles studs are too shorts.
so maybe T/A rear disc axles studs should fit?
Frank, what Wilwood kits should fit?
I checked some paterns and didn't find a front wilwood kit for snowflakes.
Prices?
ProdigyCustoms
01-21-2008, 06:26 PM
For the front, Here is the 11.75 kit instructions and Diagram. The kit is only needs a 13" diameter inner wheel hoop to clear the caliper, and the caliper only sticks out .04 which is basically nothing, so no big hub offset is needed for spoke clearance.
http://www.wilwood.com/PDF/ds218.pdf
On the rear, here is the 12.2" instructions and diagram and you can see the caliper is so far behind the hub face there is no clearance concerns.
http://www.wilwood.com/PDF/ds540.pdf
We just worked with a TA restoration shop that did this kit on a 77 TA, and there are no clearance issues. there were a couple little things. On the rear rotor there was some minor chamfering required so the rotor would seat firmly on the hub, seems that the register was not cut at a clean 90, but has a slight taper. no big deal
On the fronts, because the Wilwood front hub uses 1/2" studs instead of 7/16, the wheel lug opening had to be opened a teenie.
Other then those couple things, they work.
ProdigyCustoms
01-21-2008, 06:30 PM
As for price, here is a picture of a 12.2" / 12.2" kit which would be identical to your kit, except yours would be a 11.75" / 12.2" set. Cost is the same.
Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
Kits include:
Wilwood Parts Include:
Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Prodigy Customs Parts Include:
Front Braided Brake Hoses
Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
NOTE:
($1750 Kit includes BLACK CALIPERS and NON Drilled / Slotted Rotors)
Options include:
Red, Blue, Yellow, Silver and Polished Calipers are A + $200 Option,
Drilled and Slotted Rotors are a + $200 Option
Wilwood Aluminum Dual Reservoir Master Cylinder is a + $170 Option
Dual Diaphram Polished Stainless Power brake Booster $200
KIT AS SHOWN WITH RED CALIPERS, DRILLED AND SLOTTED ROTORS, AND POWER BOOSTER IS $2350.
O'Neall
01-21-2008, 06:58 PM
Wow, great info! Thanks Frank!
Got a question though... wouldn't 11.75 rears be a better proportionate match to the 11.75 fronts?
Any reason they wouldn't fit? Or be a well balanced set up?
PT Goat
01-22-2008, 12:39 PM
I've got the Baer Serious Street kit on the GTO, fronts and rears. They fit behind 15" Rallys, so I imagine it would be no problem with the snowflakes.
O'Neall
01-22-2008, 01:22 PM
Yeah, the Baer system looks good, but I called them and was told that they don't make it in a config that fits the 2nd Gen cars... which I thought was quite odd. Oh well....
83hurstguy
01-22-2008, 03:05 PM
The instructions say that this is for a 10.75" rotor? Radius to caliper top is 6.46"... diameter therefore 13"... but for an inch larger rotor it would be 14" , right? Is the 11.75" an upgrade?
Just curious...
woody80z28
01-22-2008, 07:36 PM
Thanks Woody.
Prices?
The factory "drum" axle studs work fine, no problems whatsoever. That's what I am still using on my car.
ProdigyCustoms
01-22-2008, 08:56 PM
Just curious...
My fat fingers, it is a 10.75 kit.
radback
01-22-2008, 11:44 PM
OK.
One more question: do theses conversions alter track width (front or rear) ?
PT Goat
01-23-2008, 01:43 PM
OK.
The Baer kit does, I believe .25" at each wheel (.5" overall).
radback
01-23-2008, 10:25 PM
but I was thinking more about 1Le and Blazer conversion.
woody80z28
01-25-2008, 07:59 PM
No I don't think so. Definitely not rear, and nothing I noticed in front.
BonzoHansen
01-25-2008, 08:11 PM
If they impact front track it is negligible.
radback
01-27-2008, 03:32 AM
OK Thanks!
