View Full Version : Primer after blastin
01somta
12-18-2007, 06:19 PM
I'm picking up my car tomorrow after getting blasted. The guy that is going to prime had me pickup the primer and activator tonight. The primer is 2k acrylic urethane, would this be ok on bare metal and hold up for a year or two until I get the paint and bodywork done? Thanks for the help.
Dustin
danbob67
12-18-2007, 06:43 PM
nope You need a epoxy primer to go over bare metal or you can metal etch first then use your urethane but the epoxy is best
chassisguy
12-18-2007, 06:44 PM
I used etching primer.
sunkistcamaro
12-18-2007, 07:01 PM
I also used epoxy primer.
TnBlkC230WZ
12-18-2007, 07:42 PM
I'd use the epoxy primer. Etching primer has limitations as to what goes on top and I don't think it seals out moisture.
danbob67
12-18-2007, 08:12 PM
You are right etch primer will not seal out moisture but the urethane will. seems much easier to just put a coat of the epoxy on than to etch prime then put the urethane on.
jilge71
12-18-2007, 09:13 PM
ppg has a good epoxy primer for that purpose...DP40LF and the catalyst that goes with... talk to willy or bud at english color on 25th and walker in okc...405- 631-4343
Dave95Z28
12-18-2007, 09:20 PM
Dustin,
Just curious as I am in the OKC area as well. Who did you have blast your car? Approximately how much did it cost if you don't mind me asking.
Dave
jilge71
12-18-2007, 09:28 PM
i had a torino blasted at a&a dry strip and they charged about 1200 for the whole car gutted and apart with the entire chassis. they did a good job but took a long time
chassisguy
12-19-2007, 08:06 PM
Pretty sure A&A did Dustins car to!
01somta
01-14-2008, 06:48 PM
Dustin,
Dave
It cost me $600 cash at A&A drystrip. This is without doors, trunk lid, any frontend sheetmetal, and they didn't do the undercarriage.
