View Full Version : Help. Completely lost
RGV_z28
12-17-2007, 09:26 AM
Got my front subframe off last night. Now don't know where to start. I'm a 22 year old college kid with two kids, so there is a bit of a budget. Here is my plan and some ?'s
1. Use stock upper/lower control arms with new polyurethane bushings, stock height disc brake spindles, detroit speed 2" drop springs, koni shocks.
2. Is there a way to use coilovers with the stock upper/lower control arms?
3. If i buy 2" dropped spindles then the 2" lowering springs, will this give me 4" of drop?
HILROD
12-17-2007, 10:11 AM
You can get coil overs that work with the stock suspension. Also you should read the suspension stuff stickied above this for a few answers.
backtobasics
12-17-2007, 11:04 AM
I think you need to provide more info, so the recommendations of the group is more relevant. Are you building a daily driver, cruiser, scca racer?
Year make model would help alot.
RGV_z28
12-17-2007, 11:24 AM
Just trying to build a cruiser. Will never be raced or autocrossed. It is a 67 camaro.
Relax428
12-17-2007, 12:41 PM
You can get coil overs for your camaro but I pretty sure you will have to at least modify your Lower Arms to get the coil overs to mount up right.
I am building a 68 Firebird and our frames are the same Im going with Global west Upper and Lower arms. I am also using Varishock coil overs.
Stay away from QA1 coil-overs they will cause you headaches and money down the road.
I know your budget is tight but you might want to look for a lower arm designed for coilovers
As for you 4 inch drop question I am not sure but I would be careful you don't bottom out
Denvervet
12-17-2007, 06:35 PM
If using stock upper control arms consider doing a Guldstrand Modification....do a search if needed. All you need to do that is a drill and a basic grinder. This will help basic handling a bunch and it 's cheap!
