View Full Version : post up some pics of your trunk moutned battery
SatisTraction
12-16-2007, 11:03 PM
I am thinking about setting my battery in the trunk and wanted to see what others have done. So post up some pics if you got them. :naughty:
69TAPoser
12-17-2007, 07:25 AM
Phil
CarlC
12-18-2007, 02:55 PM
https://www.pro-touring.com/forum/showthread.php?t=2313&highlight=bumper
LT1Nova
01-01-2008, 10:22 AM
Here is mine with my custom made pad and mounts.
I ran the cables up over the wheel wheels and used thru-panel connectors from Jeg's. I will be changing the cables out to larger ones side mount I got from American Autowire. I had just the positive run up at first and had some cranking issues and such so the ground cable got run up to the block as well.
I will be adding a rear disconnect so I can do drag racing. It will probably go through the reflector area of the tail light lens but I have not decided where to mount the switch itself so it does not interfere with normal trunk use. I will change the tail light lens and remove the rod to the switch for normal driving.
