View Full Version : miss?
gr868
12-15-2007, 12:46 PM
i have a problem with my 355 chevy it idles rough and when you have rpms steady it has a miss but when you accelerate it goes away i am stumped i thought it might be a burnt valve but pulled the heads and all lokks well any ideas?
Lowend
12-15-2007, 05:46 PM
Sounds like a text-book vacuum leak to me
gr868
12-15-2007, 08:14 PM
that's what i thought but no sign of one but i will check it again when i get my heads back from the machine shop :hand:
gr868
12-31-2007, 03:03 PM
well after spending 220$ on a valve job milling the heads flat and new z28 springs got my heads back i think my problem was a vacuum leak because the intake gaskets were trashed when i pulled them so i did a little research seems alot of people with vortec trucks are having problems with the stock gaskets i was wondering if anyone here has used the fel pro gasket #1255 with any success?
megaladon6
12-31-2007, 06:01 PM
the fel-pros are better--they have a metal sleeve at the bolts to limit crush. the most important thing is to properly torque the bolts to the right 3-stage values and the right order.
gr868
01-07-2008, 05:59 PM
well i fixed the problem and got the new wheels and tires on today but do not know how to post pics in the garage any help would be great
:secret:
Adam's 55 Chevy
01-07-2008, 09:01 PM
Put the pics on a photo web site. webshots or photo bucket. Just follow the instructions it's real easy. Once your pics are on the web;
Get the pic up on your screen after you have put it on the web and right click to open an option box.
Left click properties (last one down).
Highlight & copy URL (will end in jpeg, normally third option down)
Now put https://static1.pt-content.com/images/noimg.gif where you want the pic in the thread your posting in.
put your saved URL between the https://static1.pt-content.com/images/noimg.gif
e.g. https://static1.pt-content.com/images/noimg.gif (with no gaps)
Post reply and the pic should be there.
gr868
01-08-2008, 05:37 PM
gr868
01-08-2008, 05:38 PM
yes it worked still can't do it in the garage though:pat:
gr868
01-12-2008, 04:24 PM
well i thought i fixed it after i couldn't adjust the valves right on the fourth try i pulled the lifters only to find three wiped out!! guess its time to freshen her up
