View Full Version : Porsche brake dimensions
Takid455
12-15-2007, 08:09 AM
lokking for rotors sizes and distance between caliper attachment bolts for a porsche 996 or newer. cna anybody shed some light on this. are they close to those of a C5/6 vette?
Apogee
12-15-2007, 10:26 AM
I don't know the dimension off hand, but the Porsche 996 use radial mount calipers versus the C5/C6 axial mount design of the pad abutment brackets and similarly the C6 Z06 M-series calipers from PBR? Apples or oranges unless I'm missing something.
Takid455
12-18-2007, 06:11 AM
yes, the 996 brakes are mono block like the Z06. If I have to make a bracket, I dont mind.
Apogee
12-18-2007, 08:37 AM
Just because both of the calipers are "mono-block" doesn't make them the same...or even very similar to each other. The Porsche 996 caliper doesn't have mounting "ears" like the C6 Z06 calipers have or like the C5/C6 pad abutment brackets have (128mm center to center). The Porsche 996 calipers are radial mount, meaning that the caliper is located by radial studs, not axially oriented fasteners.
I assumed that you were going to make a bracket, however the difference in mounting widths won't matter since you'll be making it custom for your application.
Tiger
12-18-2007, 10:46 AM
if you want Porsche calipers with "ears" you can do as I did and use C ayenne calipers. they are six pistons and made by Brembo.
Takid455
12-18-2007, 01:24 PM
hmmm:idea: ... any pics?
4OfaKind
12-18-2007, 05:39 PM
Try calling these guys: http://www.electro-dynamics.com/
They make parts to install porche rotors on C4 vettes, maybe they have something for C5/6's also. They might be able to answer all your questions.
Mal
Tiger
12-19-2007, 02:02 PM
here ya go man
Tiger
12-26-2007, 10:25 AM
one more
Takid455
12-27-2007, 07:04 AM
what diameter rotors are you running?
Tiger
12-27-2007, 10:56 AM
they are 360mm, should be something like 14.25" if I remember right
TonyL
12-27-2007, 01:04 PM
360 millimeters = 14.1732283 inches
andrewb70
05-26-2008, 07:38 PM
here ya go man
Do you happen to know the piston sizes for that caliper?
whytry
05-30-2008, 07:28 AM
Holy rotor batman!!!
