View Full Version : Have AFX spindles for my Grand National, need some part numbers for brakes
jdpolzin
12-14-2007, 06:35 PM
Hello guys, I have a set of AFX spindles for the GN and I just bought a new set of ZO6 calipers as well. These are not the loaded calipers so I will need everything else........Caliper brackets, hardware kit, bolts, PINs, etc.
What all am I going to need and what are the part numbers? Quantity? I looked into Oreilly Auto Parts online and they saw I need 1 hardware kit. What all does this include? I also see they have a bolt seal kit, what is this? Thanks! -----Jeremy
12-14-2007, 09:04 PM
all i have are factory numbers....spring plates come with the pads.
C5 ZO6 (red caliper) PARTS LIST
caliper: 88895128 88895129
pad cage : 12455799 2 req.
boot kit : 12530703 4 req.
guide pin : 12530697 4 req.
rotor : 10445856 10445857
banjo bolt : 11518571 2 req.
copper crush washers 4 req.
Bracket to spindle bolt : 11508133 4 req.
caliper to cage bolt: 14067559 4 req.
bracket to cage bolt: 39685 Fasenal M14-2.0x35mm Allen head
Wheel stud: Dorman 610-323 OR Napa 641-1581
jdpolzin
12-15-2007, 09:51 AM
Ok great. What is the cage? Also, what are the copper crush washers used for?
jdpolzin
12-15-2007, 10:04 AM
I dont mean to be a pain in the butt here but could you give me a breaf description on how everything fits together? Which bolts go where and such?
12-15-2007, 10:14 AM
your really being a pain, nah its not a porblem.
The cage is what they call a abutment or pad support. The bracket that houses the pads.
The copper washers are for the banjo bolts that connect the brake fluid line to the calipers. One on each side of the line connection.
I'll see if I can find the break down picture. I had it some where. Its not as difficult as you think it would be.
jdpolzin
12-15-2007, 10:16 AM
Here is a list that Mark at www.scandc.com (http://www.scandc.com) gave me. I'm trying to figure out the differences between the two lists. I am going to order these parts but I dont want to pay for the same things twice. I noticed you have a few parts that he doesnt have listed and he has a few you dont have listed.
C-5 brake parts list
The following are stock GM `97-`04 Corvette or direct replacement parts:
Caliper mounting brackets
GM#12455799 Qt.2
Caliper bracket bolts
GM# 14084051 Qt.4
Calipers
RH GM#12530682 / LH GM#12530683
Caliper guide pins
GM# 12530697 Qt.4
Caliper hardware kit (includes brake pad anti-rattle clips and guide pin
retaining bolts)
NAPA United #83212 or equivalent Qt.2
Hub/Bearing assys.
SKF#BR930099, Timken#5131139 or equivalent Qt.2
Lower Hub/bearing assy. retaining bolts
GM#10414261 Qt.2
Rotors
Wagner BD125539, Raybestos 65701 or equivalent
Brake pads
Any `97-`04 C-5 Corvette direct fit pads
CHILI442
02-25-2008, 10:51 AM
The part number for the Banjo Bolt has been superseded. It is now 11570052. It only took them two weeks to get them :confused:
02-25-2008, 12:41 PM
Thank Chili,
did you go through GM part direct? I will have to check my notes for a Dorman aftermarket replacement.
Can't believe how much of it is superseded.
CHILI442
02-25-2008, 01:56 PM
I went through the local Chevy dealer. Napa had nothing and Autozone's website showed nothing. My local part store that always takes care of me (not the typical chain joint) showed 3 different banjo bolts. (2) 25mm and (1) 28mm - all same thread, but couldn't tell me which was correct. So in frustration I went back to the dealership and told them to order them for me. I figured $10 for two bolts is better than driving all over the place getting jerked around.
Anyway, I appears the part number has changed three times. What I posted above is what they gave me.
andrewb70
02-26-2008, 04:29 PM
Does anyone know the actual piston sizes on the latest ZO6 calipers?
