View Full Version : Stainless AN fittings
Tiger
12-13-2007, 11:12 AM
does anyone know if any companys make AN weld-in fittings and bulkheads in stainless steel?
I'd need some AN-6 and some AN-10 or AN-12 for gas tank fabrication.
thanks!
parsonsj
12-13-2007, 11:52 AM
Andre
I never could find any. I ended up welding in ss pipe fittings and then used NPT-AN adapters.
jp
CarlC
12-13-2007, 04:43 PM
Try a Parker store, or another industrial hydraulic distributor.
zz3elcamino
12-13-2007, 05:01 PM
This is the joint right here. Godman Hi Performance, they carry all kinds of SS AN fittings, but they will cost you a pretty penny. Hope this helps you out!
http://www.godmanhiperformance.com/
Jason
Twentyover
12-13-2007, 05:02 PM
If you can't find weld in fittings, take a tube to tube fitting, cut one end off and weld the other?
ironworks
12-13-2007, 07:23 PM
There is a company that sells them, but I cannot remember what it is called. It is on my favorites on mywork computer. They sell everything. I have to reorder brake line fitting tommorrow.
Rodger
ironworks
12-14-2007, 09:34 AM
www.jdaent.com (http://www.jdaent.com)
Tiger
12-14-2007, 09:41 AM
thanks guys!
I'll look into the Goodman page and see if they have what I need.
in the meantime I've found that Isa Racing in Germany have them but in AN-6 AN-8 only.
I want to build a tank that for now will be used for a carbed smallblock but I want it to be ready for a carbed or EFI smallblock with around 7-800HP in case I ever get rich.
What size fittings should I use? my idea was 2x AN-6 (one vent and one return) and then one AN-10 for fuel.
Tiger
12-14-2007, 09:42 AM
thanx!
Tiger
12-14-2007, 10:48 AM
John,
where did you get your stainless NPT weldins? it doent seem like these guys have any, they do indeed hve bulkheads and NPT-AN adapters :o)
thanks again
ironworks
12-14-2007, 03:48 PM
I spent about 1000 bucks this morning on there parts. Stainless arp bolts and Stainless brake line fitting.
Rodger
Tiger
12-21-2007, 02:14 PM
I ended up getting what I needed from JDA, great service and fast shipping.
Twin_Turbo
12-21-2007, 07:43 PM
i must be blind, can't find weld fittings in stainless on JDA site, only stainless adapters which would have to be cut. Max size is also dash 12 :( I need 16 for my dry sump stuff...dang!
Tiger
12-22-2007, 10:41 AM
I bought stainless adapters that are to be cut.
anyone have an Idea for a fuel tank cap that is to be fitted on the end of a 2" stainless tube?
thanks!
scotzilla
01-08-2008, 07:27 PM
tmr in orange , ca
714-771-1348
GOod prices too-
Tiger
02-07-2008, 12:46 PM
The JDA parts finally arrived to Europe today, absolutely top shelf parts.
Service was great to
thanks!
https://www.burtonpower.com/product_main.aspx?prodLanding.aspx?CCode=PC800
Olav
Tiger
02-09-2008, 11:14 AM
thanks Olav, I appreciate it
I already bought this one though
Marine filler caps..... remember to make vent on the tank, these are water tight/ sealed.
Olav
Tiger
02-10-2008, 09:51 AM
yeah I will have a vent with a rollover valve.
I know all about not vented tanks, several years ago I changed the gas cap because the old one leaked, I managed to get a non vented cap and after about 50km the tank was flat. :o)
