View Full Version : Pics of GM progressive rate bump stops
67speedfreak
12-09-2007, 08:20 PM
Here is a pic of the GM progressive rate bump stops installed on a 68 Camaro. Thanks to Mark at SCC for turning me on to these.
https://static1.pt-content.com/images/pt/2007/12/IMG_1797-1.jpg
syborg tt
12-10-2007, 07:36 AM
so where do you get these ?
67speedfreak
12-10-2007, 07:57 AM
You can get these from your GM dealer.
I believe Mark said they were stock on S-10s and GMC small trucks.
SHANE 73Z
12-10-2007, 08:04 AM
With the ZQ8 suspension package.
Apogee
12-10-2007, 08:15 AM
GM #15956547 (Thank you Marcus)
The slightly softer part number has been discontinued and replaced by the number above.
67speedfreak
12-10-2007, 09:02 AM
You are right Sir.
Thanks for posting.
I have yet to try these out but they just make good sense.
12-10-2007, 07:24 PM
What about the cushion mounts? Are they weld or bolt on?
67speedfreak
12-10-2007, 08:18 PM
They are bolted to the control arm.
12-10-2007, 09:34 PM
How about the set up as pictures here. The metal pocket is bolted to the frame? Is it included with the cushion? thanks
67speedfreak
12-11-2007, 05:48 AM
Yes the cushions come mounted in a steel cup with a 5/16 stud for mounting.
Sorry misunderstood the first time.
James OLC
12-11-2007, 06:26 AM
Do you know how tall they are?
Apogee
12-11-2007, 08:06 AM
The bumper is 2-3/4" from the bottom of the steel cup to the top of the cone. The stud is 3/8-16 and extends just over 11/16" (.70") from the bottom of the cup.
The urethane (or whatever it is) bumper is locked into the steel cup by three tangs that are pressed inward. You may have to grind the lip on the steel cup a little to keep it from interfering with some coil springs.
TheBandit
02-20-2012, 11:06 AM
Do these work well/okay in a factory LCA application?
syborg tt
02-20-2012, 12:02 PM
Well I am not going to pick on you here. But they are stock and the 2Gen ZQ8 s10 Pick Up with factory stamped lower control arms. I even used them on my 1st Gen s10 and they worked great.
The question is will they work for your application. Most likly
opps - here is the link to buy them
http://www.rmsautoparts.com/proddetail.php?prod=15956547
TheBandit
02-20-2012, 12:04 PM
I should have been more specific. I mean for a stock LCA in a '67-'69 Camaro, Firebird or '68-'74 Nova. The OP shows aftermarket LCAs with the bump attached to the frame. I'm thinking about a stock LCA with the bump attached to the LCA. Overall it seems pretty tall for this though?
BonzoHansen
02-20-2012, 12:12 PM
anyone ever use these? the dorman version?
http://www.dormanproducts.com/p-27359-31064.aspx
syborg tt
02-20-2012, 12:26 PM
Looks to be the same part
You can also use this one for tight clearence
http://www.energysuspensionparts.com/proddetail.asp?prod=9.9102
http://www.energysuspensionparts.com/Energy-Suspension-Universal-Bump-Stops-Shock-Eyes.asp
SLO_Z28
02-20-2012, 01:49 PM
Im a fan of these:
http://www.energysuspensionparts.com/proddetail.asp?prod=9.9150
"Z28" style bump stops.
