SamHatco
12-09-2007, 04:03 PM
I have a 69 vert that I'm putting a LS1/t-56. I just pull the rear end and this is the code on the passenger axle. JD G102 1 on the center section is the code C302. I believe it is an 8.5 10 bolt. It takes an 1 1/4" socket for the pinion nut.
If it is an 8.5 10 bolt, what upgrades do you guys recomend. I know that I want a 3.42 gear, but I'm uncertain as to which way to go for the posi trac, axles and yoke. Any help would be appreciated.
Sam
Sam
