View Full Version : spacer bearings opinions please
indyjps
01-18-2005, 03:06 PM
whats everyone think of spacer bearings. 350 crank in 400 block. any horror stories on 377 buildups. dont know if i trust them. what specific machine work do any users recommend.
Salt Racer
01-18-2005, 04:23 PM
I had a 377 with Procharger on my daily driver Nova a couple of years ago. I had Comp Cam spacer bearings. I bought everything else from Lunati (crank, actual bearing, prep'ed OE 400 block, etc). Put 30,000+ miles on the motor before I cracked a couple of pistons. The motor had seen several 2000-mile road trips as well as 10+ drag strip passes.
I don't see any problem with spacer bearings as long as all machine work are done correctly and the motor is assembled right. But I personally don't recommend it to somebody else if he/she can afford a crank or a block with correct main journal size.
I thought someone makes bearings with thick shells for this application now, but I could be wrong.
Kenova
01-18-2005, 06:47 PM
I'm sure these thicker bearings are still around, but don't know who is making them :dunno:
Ken
