View Full Version : hydraluic to a solid?
copo69
08-18-2004, 06:28 PM
is it possiable to take a 647 647 lift 254 266 at 50 thousands big block roller cam and pop in a solid lifter ? ever done this can it be done what are the drawbacks if any ?.. thanks for the help
chicane67
08-18-2004, 09:12 PM
That would be answered by the manufacturer of the camshaft itself. To speculate would be a waste of your time.
copo69
08-19-2004, 07:45 AM
yes you can convert any cam from solid to hyd or from hyd to solid /. just checking .. and chicaine is right before you do this you should check with the cam maker as to the recomendation for lifter and lifter lash in the case of a solid ...nice to see someone on their toes
ProdigyCustoms
08-19-2004, 12:13 PM
we are being tested.
derekf
08-19-2004, 12:46 PM
A census taker tried to test me once. I ate his liver with some fava beans and a nice Chianti.
No! The lifter bodies are totally different. Not to mention the lobe profile of the cam from roller to flat tappet as well. Don't do it.
dennis68
08-22-2004, 05:23 PM
What do lifter bodies have to do with using a solid lifter on a cam ground for hydraulics‘?!?! As for the grind's, hydraulic grinds are much less aggressive than solid grinds, I'd be much more worried about going from solid's to hydraulic than the other way.
The hiegth...Stick a roller on the end, it gets taller. It's not my engine, do what you want to with it.
Matt@RFR
08-23-2004, 07:06 AM
Brad, unless I misread too, the original question is concerning hydraulic rollers and solid rollers, NOT flat tappets. Besides, any difference in hieght of a lifter body can be accomodated by shorter pushrods.
I may have mis-read that too. I do know going flat tappet to roller is no good. As roller cams are made from billet. So a soft, flat lifter on a hard cam will kill the lifter, other way around willl kill a lobe. As for going from one roller to another roller....let us know how it works out.
ProdigyCustoms
08-23-2004, 02:28 PM
Is OK. In fact, I have someone doing one right now in a hydraulic appilcation that is floating at 5700. Called the cam company, and they seemed to say, well, you may have to use solids! They recomended the swap to solids. Kind of sucks because they made the cam for 6500 RPM operation, but their lifters only go to 5700? Whatever!
