DCx
12-07-2007, 02:09 AM
i bought a painless relay bank to control my fuel pump and my fans in my 69 camaro. the relay bank has 3 40amp relays and a single 50amp circuit breaker.
my question is, will the single 50amp circuit breaker be enough for stock F body LS1 fans and an edelbrock fuel pump? i thought you were supposed to run inline fuses from each relay to the battery. should i drop the circuit breaker and run inline fuses instead?
i was going to wire my fans for ground activation because im running a painless thermostat switch, 205* on 190* off, that screws into the cylinder head.
i was then going to wire the fuel pump relay for power activation. here is the instruction manual.
http://www.painlessperformance.com/Manuals/30107-30108Instruction.pdf
