View Full Version : First-Gen S10 Corner Carver
Pages : 1 [2]
jerome
08-05-2018, 09:14 AM
s10mike - i know I already replied by PM but for anyone else wondering, we just notched the factory bracket and remade part of it with a flat strap to lay right on the condenser, you can see it in the pic below
https://static1.pt-content.com/images/pt/2018/08/42608953074_a80d8c452b_b-1.jpg
Re-assembly is slow, but it's nice to see it starting to come back together
https://static1.pt-content.com/images/pt/2018/08/42608953304_222c31ccc8_b-1.jpg
https://static1.pt-content.com/images/pt/2018/08/43277028672_0b57f853d0_b-1.jpg
We tried lengthening the lower control arms but ran into clearance issues, so those will need to be re-made in a different shape. The wheel hits the control arm at a pretty steering angle. In the picture above, the wheel is turned as much as it will go. In the picture below, you can see the contact
https://static1.pt-content.com/images/pt/2018/08/43817464392_c0daec4848_b-1.jpg
We got longer adjusting sleeves for the upper control arms to lengthen them but those too had a clearance problem
https://static1.pt-content.com/images/pt/2018/08/43865852401_030332eea9_b-1.jpg
The solution was to cut the welded clevis off the ball joint plate and re-weld it more in the center of the plate (top before, bottom after)
https://static1.pt-content.com/images/pt/2018/08/43817398362_ba97620b3a_b-1.jpg
JayinMI
05-12-2020, 07:47 PM
Necro bump, but did this ever get finished?
Jay
jerome
05-27-2020, 10:25 AM
Jay
The project continues on but progress is pretty slow.
U-pol raptor liner sprayed in the bed
https://static1.pt-content.com/images/pt/2020/05/49941959773_0b9f5530b5_o-1.jpg
Front fenders mounted
https://static1.pt-content.com/images/pt/2020/05/49942475476_66b3ba160b_o-1.jpg
Tailgate mounted
https://static1.pt-content.com/images/pt/2020/05/49941959808_5fef09d2c4_o-1.jpg
Work remaining:
Wiring and miscellaneous interior fabrication
Mount grill, air dam and splitter
Front brake cooling - backing plates, hose routing, ducts in air dam
Install hood, reinforce structure, prep and paint
Interior upholstery
Windshield (glass) and rear window (lexan)
Bed cover
JayinMI
05-27-2020, 03:53 PM
Thanks for the update. Wasn't sure if you maybe had it on other forums, and forgot this one or if it just slowed down. I'm building an S10 of my own, so this is a thread I like to follow.
Jay
syborg tt
05-28-2020, 06:41 AM
I am happy you are still working on the truck and the good news is your list is getting smaller and smaller.
My goal on the 70 is to try to go out to the garage every day and just do a little something and it actually works.
mj
Work remaining:
Interior upholstery
Bed cover
alderfek
01-05-2021, 07:43 AM
Love the build so far. Any more updates ? Going to have to steal that color for the two-tone on my Jimmy. Should go great with White.
183095
BK2LIFE
01-05-2021, 10:02 PM
lookin great!!
Hotwire
01-06-2021, 06:35 AM
Are the upper arms hitting because the suspension is drooping? Could that be a non-issue at ride height / normal suspension travel?
BK2LIFE
05-20-2021, 06:24 AM
dang nice, never seen the bedliner sprayed so smooth before.
maro67
05-30-2021, 06:30 AM
You can also look into a multiport throttle body setup using a standard style is brake manifold. Look at the Edelbrock systems that come as a turn key package. Also Holley sells the intake manifolds with bungs already drilled and tapped to accept I Hector's in each intake runner. The throttle body only flows air no fuel. The main benefit over the sniper style system is that the fuel is injected into each intake runner individually just before the intake valves / combustion chamber so you get a uniform amount of fuel in each cylinder.
Cheeks
02-18-2022, 07:49 AM
any more updates? would love to see the finished product
