View Full Version : Need exhaust system for lowered first gen F body need clearance
Steve Firebird
12-01-2007, 06:32 AM
I have a 1968 firebird with 3" drop leaf springs and a QA1 coil over convertion on the front. My sub frame has about 5" of clearance and thats about right for were I live and drive. My mufflers hang down too low. They are at about 3.5 inches and its just too low for me. What are all you guys with the lowered cars running for exhaust systems. I am running factory ram air exhaust manifolds so there is no clearace issues on that part. I would like to find a system that will not hang below my sub frame. Any pictures of what you have would be great.
Project69
12-01-2007, 07:18 AM
Every muffler exhaust system will hang lower then the frame. What you can do is call up flowmaster and tell them to include there low-profile race muffler instead of there 40-series.
I use cherry bombs, with magnaflow resinators before them. Sounds great but a tad on the loud side.
HILROD
12-01-2007, 07:22 AM
I have a Torque Tech 3 into 2.5 X pipe system. I intalled it myself and it hangs up at least as high as my subframe connectors. Great fit. It sounds like you just need a little work to tuck it up, if it's still solid.
nicks67camaro
12-01-2007, 10:48 AM
spintech oval there is no "system" but I have after my 3 inch round x pipe an oval 3 inch with oval sportsman mufflers sounds sick and I have super clearance.
uwntsumrtII
12-01-2007, 11:20 AM
as mentioned Spintech but also Dr. Gas has a variety of oval tubing as well.
http://www.spintechmufflers.com/spintech/spintechindex.asp
http://www.drgas.com/store/home.php
Steve Firebird
12-01-2007, 11:48 AM
Thanks I will check it out. I think if I went with the oval tubing and a transverse mounted dual in out muffler were my gas tank use to be I could keep it tucked up pretty well.
b-man
12-01-2007, 12:01 PM
There is an install story featuring the 1st gen Firebird 2-1/2" Pypes system with Doug's Headers in the current (Jan/Feb '08) issue of Pontiac Enthusiast.
Supposed to have great ground clearance, might be worth checking out.
rocketman
12-01-2007, 09:11 PM
Use oval pipe, and build a crowflow system, like a factory chambered exhuast
Steve Firebird
12-10-2007, 08:21 AM
I found a a couple crossflow systems I like .
http://www.hottexhaust.com/detail.asp?PRODUCT_ID=15895
http://www.pypesexhaust.com/sys-fb1.html
Taylor1969
01-10-2008, 08:56 PM
I have Doug Thorley Tri Y's that feed into a pypes xpipe true dual... The ground clearance is amazing. I can get pics of the full exhaust this weekend, but for now, I have pics of the headers...
https://static1.pt-content.com/images/pt/2007/09/IMG_2613-1.jpg
Steve Firebird
01-11-2008, 02:32 AM
That looks good I will be interested to see how the pypes system tucks up under the dar.
redfire69
01-11-2008, 02:51 AM
If you like flowmaster and crossflow, their system 17104 is great. I had it on my 80 TA for a while, it fits 67-81 non verts. You'd just need some down pipes.
Ron
https://static1.pt-content.com/images/pt/2008/01/flo17104_w-1.jpg
Taylor1969
01-16-2008, 04:20 PM
I forgot to take pics this last weekend when I was working on the car. I'll be sure to take some this weekend. It tucks beautifully...
Steve Firebird
01-18-2008, 03:39 PM
Ron
I had a 79 TA with that system and liked it but I want to go with a x pipe set up thanks
Steve Firebird
01-18-2008, 03:49 PM
Thats cool no big rush it's blow zero here this week end so I have plenty of time.
Taylor1969
01-27-2008, 08:00 AM
Here is a shot from behind... notice the angle of the picture. When looking straight ahead the mufflers are above the rear...
https://static1.pt-content.com/images/pt/2008/01/IMG_2714-1.jpg
Here is a straight on shot from the side... notice that you can't even see the pipes because the tuck under the frame...
https://static1.pt-content.com/images/pt/2008/01/IMG_2716-1.jpg
Taylor1969
01-27-2008, 08:02 AM
Another far shot...
https://static1.pt-content.com/images/pt/2008/01/IMG_2718-2.jpg
Taylor1969
01-27-2008, 08:06 AM
One more to show how the mufflers tuck...
https://static1.pt-content.com/images/pt/2008/01/IMG_2709-1.jpg
Taylor1969
01-27-2008, 08:08 AM
Specifics...
Doug Thorley Tri Y Headers
Pypes x-pipe
magnaflow mufflers
Total cost for me was ~$650
Steve Firebird
01-27-2008, 06:02 PM
That looks great thanks for the pictures.
NvrDun71
01-28-2008, 01:41 PM
Specifics...
Pypes x-pipe
magnaflow mufflers
Happen to have any pics of the Thorley's off the car before they were installed? Ground clearance looks excellent....
rohrt
01-28-2008, 01:47 PM
No one has mentioned the RARE oval system. Not cheap but looks good.
http://www.ramairrestoration.com/catalog/index.php?cPath=31_1&osCsid=9e4135c85ebebb7e0d034f98f3defc58
Curley
01-28-2008, 02:04 PM
Here are pictures of my 376-Yc Thorleys if that helps...
https://static1.pt-content.com/images/pt/2008/01/Camaro041-1.jpg
carguy502
01-28-2008, 04:04 PM
did those tri-ys interfere with clutch linkage, mechanical or otherwise? do you happen to have a pic of the headers installed right next to the drivers side bellhousing?
Curley
01-29-2008, 11:28 AM
No interference with the mechanical clutch linkage. It was a pain trying to get the Z bar back in, but once there it does not touch anything. I dont have a picture from underneith, but I do from above. I'll try to snap a picture later. Here is above...
https://static1.pt-content.com/images/pt/2008/01/Camaro069-1.jpg
You can see to the left of the steering box is the return spring. Then look at the second spark plug shown and look straight down to see the felt and the Zbar.
Here is one with the engine out of the car
https://static1.pt-content.com/images/pt/2008/01/Camaro021-2.jpg
Curley
02-01-2008, 05:49 PM
Sorry it took so long but here are a few pictures from underneith.
https://static1.pt-content.com/images/pt/2008/02/Camaro083-1.jpg
https://static1.pt-content.com/images/pt/2008/02/Camaro079-1.jpg
https://static1.pt-content.com/images/pt/2008/02/Camaro077-1.jpg
carguy502
02-02-2008, 01:29 AM
Thank you for the pics. They are just what I needed to convince me that tri-ys are my next purchase following all the money I am putting into my chevelle.
Curley
02-02-2008, 05:01 PM
No problem sorry it took so long.
68Formula
02-03-2008, 12:36 AM
Just to be sure everyone is clear, both Dougs Headers (b-man's post) and Doug Thorley headers have been mentioned in this thread. These are two different brands.
