    Results 1 to 6 of 6
      Waterloo, Ia
      Benifits of a larger wheel??
      This winter I am taking on the back end of my 73' Nova. It has already been backyard minitubbed by the previous owner. I have over 13" in the wheel well area.
      The things ive decided to do are as folows.
      1. Install DSE offset rear shackles
      2. Purchase a new rear end housing from Quick performance because my old one is bent and not able to be straightened.
      3. Install scarebird rear disc brake setup.
      4. Fabricate a frame rail and move my rear shocks inboard
      At this point i will have a bit over 13" in my rear wheel tub. I currently have a 275/60R15 In there and theres 3" of clearance between the frame and the tire at the closest point. Im planning on going to a 10" wide wheel, probably 7.5" backspace and possibly a 305 or 315 series tire if it will fit reasonably. {I may need to narrow my rear end}
      Now heres my question. Whats the benefit of going from a 15" to a 16" or 17" wheel? Are the benifits worth it? Is this more of a looks thing? Im not going to be able to afford a high dollar big brake kit ever so Im thinking about staying with a 15" wheel because I like how they look. Im probably going to go with this wheel.
      http://www.billetspecialties.com/ite...pid=940&rdir=1
      Any opinions? Any ideas for reasonably priced tires? All ideas and comments are welcome. Im trying to put the finishing touches on my project plans!!
      -Nick
      -1967 GTO I drive and race
      -Build threads:
      Aug 2005
      Patterson, NY
      The shorter the sidewall the less flex in the tire (typically), which leads to better handling, but can hurt in straight line traction.
      Other than that, I think it's mostly looks.
      May 2002
      Northern California
      excellent, plus more room for more brakes. 17's are a perfect balance.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Flo-rida
      Big wheels = more bling
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Henderson,NV
      Most wheel designs just don't look good until they hit 18" but thats my opinion.
      Todd
      Apr 2007
      Ohio
      ME LOVE 18"s ALSO!!!
      So anyhoo, I personally either prefer an original style 15" or a tastefully chosen aftermarket 18" wheel that isn't overly chrome or blingy, a lot of 16"s & 17"s in between just kind of look half-way there. However, depending on the stance and tire profile I've seen a few 17's that look pretty good to.
      & if you don't currently have a big pro-touring budget, I'd think you'd be better off saving up your money for a good set of 17's instead of spending it on new 15s, since 17's make a big difference in the turns with less sidewall flex. Plus, if you've already invested all that time fabricating and are aiming to have a serious pro-touring car, and not so much a street-strip type car theres no reason not to go for lower profile tires!
      Take a look at this thread a few posts down from 67lemanster, he and a few other members on NastyZ28 have purchased the Crager Soft 8 wheels from around 50 bucks a pop from jegs, or summit + tires for about $600.00 which isn't bad once you get into the low-profile tires. http://www.nastyz28.com/forum/showthread.php?t=47101
      Now of course those are steel wheels, so your looking at a lot of rotating inertia which goes best with BIG brakes, but if all else a good set of Hawk HPS pads on the front discs (provided you don't have all wheel drum) and a clean operating brake system should offset that a little and you'll still be in the green with the additional cornering capabilities provided by your new 17"s!!!
      -6Spd EFI 1980 Camaro Z28 - Street Fighter - Amongst other GM autos. Atomic Orange Z06 is next!
