View Full Version : 383 LT1, what rods?
Samckitt
11-27-2007, 02:50 PM
I would like to build one with 6" H beam rods. Anyone know which rods have the best clearance?
Scot
Lowend
11-27-2007, 03:20 PM
They are I-Beam's but you will be hard pressed to find a higher quality and better clearance rod than the Crower Stroker Sportsman.
H-Beam is no stronger than I-Beam - that is a myth
Samckitt
11-27-2007, 03:46 PM
Wow, those are about twice as much as I was looking to spend.
Lowend
11-27-2007, 06:28 PM
Well - good old Scat 6" I-Beams with a small base circle cam will get you a long ways in this world. What kinda money you wanna spend and kinda power/RPM you planning to make
rocketman
11-28-2007, 09:06 PM
Eagle rods or Oliver billet rods.
Samckitt
11-29-2007, 05:30 AM
I thought my clearance problems is between the rods & the block, not the cam...? What kind of money do I want to spend? As little as possible :-) A couple grand? Would like to make around 450hp.
Samckitt
11-29-2007, 05:47 AM
What do you think about buying engine parts off of Ebay? Found these:
http://cgi.ebay.com/ebaymotors/NEW-SBC-6-SCAT-4340-CONNECTING-RODS-7-16-CHEVY-GM-383_W0QQcmdZViewItemQQcategoryZ33623QQihZ011QQitem Z320187752571QQrdZ1QQsspagenameZWDVW
Never mind, looks like they are less from Summit racing.
Lowend
11-29-2007, 05:21 PM
Ebay engine parts make me nervous - they are often factory 2nds.
Go to reputable shop they are all gonna charge about the same, apples for apples
rocketman
11-29-2007, 06:27 PM
A 6 inch rod in a 383 will hit the cam if it's not a small base cirlce cam, a 5.7 is better option if not wanting alot machine work. and if 450hp is all you want a 355 will make that or build a 406 cheaper
Samckitt
11-29-2007, 08:31 PM
What could I get from a 383, hp wise? I want fuel injection & I like the LT1 looks over any after market throttle body looking setup. Would rather stay with the Gen I or II small block.
rocketman
11-30-2007, 12:23 PM
I have seen 500hp 383 Lt1's, there kinda common. I have a 94 Z I have a 355 and it makes it at 500hp(lt1)
Samckitt
11-30-2007, 03:36 PM
Naturally, turbo, blower? What specs on the cam, compression heads & so on?
rocketman
12-01-2007, 10:30 AM
Afr 195 Lt4 heads, basicly out of the box, ports cleaned up and matched to Lt4 intake, 2.05/1.60, 11.5 comp, Solid roller 240/248@50 585/595 lift 112 cl,
Now this isn't a proven 500hp set-up I've never dyno'd it, I finished the motor and put it in the car, But from my exp building engines, it's should be real close give or take a few hp.
I have the bottle on it but haven't sprayed it yet.
Samckitt
12-04-2007, 06:04 AM
If I was to use 6" I beam rods, are you sure a small base circle cam is required. A guy I work with has a 406 with 6" rods & a normal base circle cam with no problems.
MarkM66
12-04-2007, 12:54 PM
I ran the Scat 6" I bean 7/16" rod bolts rods on a non small base circle cam in a 383 and it worked just fine. I think they were about $300.
Lowend
12-04-2007, 01:22 PM
You won't know for sure if you need a small base circle until you get the motor together and turn it over by hand. Considering that a ordering a cam on a small base circle costs ~$20 extra - its cheap insurance
Samckitt
12-04-2007, 02:48 PM
So that would also require different pushrods, & obviously the cam is different, both of which I already have. So if/when the day comes I will just have to try it & see what happens. Thanks.
rocketman
12-04-2007, 05:33 PM
You could also skip the 6 inch rods and use 5.85 rod. 9 out of 10 383 will need a small base cam, the small base circle cam keeps from grinding the head of the rod bolt.
MarkM66
12-05-2007, 05:43 AM
Use a rod that uses cap screws.
rocketman
12-05-2007, 11:29 AM
Thats what I normally use, I wasn't sure if he was or not, so I made that comment.
AButler
12-06-2007, 10:37 AM
I second these. They appear to clear but i dont have my cam in yet to say that 100%. The cap screws on these help also. Just my.02
Aaron
