View Full Version : Momo hub to fit 67 camaro?
67ragtp
11-19-2007, 06:32 PM
Ive been searching and reading all the posts on the hook up for a momo wheel on a 67 camaro column and Im now totally confused.
Ive got a few questions, will the 2401 hub work on a 67 tilt column or does it require mods? what needs to be altered if anything?
I just want to hook this up with least amount of adapters as possible, what do I purchase?
Any one with 67 or 68 I would really like to know what hub to buy, Thanks Rich
Hammered
11-19-2007, 07:15 PM
If it's for a '69 or later column, the OD will be about 0.25" too large and there will be about a 1/8" gap between the column and adapter. Otherwise it should bolt up.
ProdigyCustoms
11-19-2007, 07:23 PM
Is your tilt column a factory tilt or aftermarket tilt? The MOMO will bolt right up to a IDidIt.
Steve68
11-20-2007, 02:59 AM
Then the key will be in the wrong place,
67ragtp
11-20-2007, 03:59 AM
frank- its a factory tilt column.
Steve - what do you mean, the key will be in the wrong place. There is no key on the shaft(splined) and if you are refering to the ignition key its on the dash on 67s.
Rich
