View Full Version : grand national wheel set up
tb8125
11-18-2007, 03:37 PM
Hey guys I am trying to get my car's stance set up I want to know what you guys think I should do I was thinking of leaving the back stock and dropping the front 1 or 2 inches
now its stock set up
with 20.10 with 5.5 back spacing and the tires are 275 40 20
and 18.8 with 4.5 back spacing and the tires are 245 40 18
West Texas Z
11-18-2007, 03:42 PM
drop it all around IMO.
TPI Monte SS
11-19-2007, 09:22 AM
I don't think you can go much lower in the rear without running into the fender lips. I'd leave the rear ride-height alone, and drop the front 1.5" or so. JMO, of course.
tb8125
11-19-2007, 10:58 AM
I was thinking the same way I thought 2 inches would be too much and 1 not enough.... I was told to do springs not spindles because I will get some rubbing using the spindles
TPI Monte SS
11-19-2007, 06:04 PM
Drop springs on a G-body are the way to go (IMO anyway). I'm very happy with the Eibachs, but there are more budget-friendly options, especially if you're gonna leave the rear alone and just change the front springs. You could even try cutting a half coil off your stock springs first to see if the ride height is where you want it, and how it rides. Otherwise, switching to S10 drop springs or Moog 5660s will work.
jdpolzin
11-24-2007, 03:27 PM
I cant believe the 5.5" backspace on the rear works without notching to frame! I have 5.5" backspace on my GN and have to have the frame notched. This is also with aluminum drums which brings the wheel out 3/8".
tb8125
11-28-2007, 06:26 PM
tes the frame will have to be notched
