View Full Version : Chevy engine weights
Tiger
11-14-2007, 03:41 AM
Hi all,
To continue planning my Chevelle I'd like to know the approximate weight of the following engines.
1. SBC all iron except intake manifold.
2. SBC iron block, aluminum heads and intake.
3. SBC all aluminum.
4. BBC all iron except intake manifold.
5. BBC iron block, aluminum heads and intake.
6. BBC all aluminum.
thanks guys!
:barf:
Adam's 55 Chevy
11-14-2007, 04:46 AM
Hi all,
1. SBC all iron except intake manifold. = 555lbs
2. SBC iron block, aluminum heads and intake. = 500lbs
3. SBC all aluminum. = ?
4. BBC all iron except intake manifold. = 665lbs
5. BBC iron block, aluminum heads and intake. = 600lbs
6. BBC all aluminum. = ?
thanks guys!
:barf:
Remember headers, long short water pump, ally water pump, steel or billet pulleys, electric fan, ally rad etc all make a difference. The only real way is to build what you want and weight it but these weights will get you close enough.
Tiger
11-14-2007, 06:20 AM
thanks Adam!
I know but with your numbers I'm able to get an idea of what several $$$ are worth weightwise.
and yeah, sorry for the puking guy, when I put it in it seemed like a smiley :o)
Taylor1969
11-14-2007, 09:30 AM
LS1 should weight apprx. 390 lbs
Tiger
11-19-2007, 01:34 PM
Hi,
I found out that an all-aluminum SBC is 355lbs.
