View Full Version : Need a good soldering iron or gun.
Rileys68Camaro
11-11-2007, 08:36 PM
Every one I've used takes so long to heat the connector, it's not even funny. Half the time they only melt the solder with direct contact with the solder and that can't be good.
The way I was taught was to 'tin' the tip of the iron, and then heat the part to be soldered with the tip and remove the heat and add solder letting it flow into the connection. Is this correct.
Thanks!
Don't remove the heat before applying the solder or a cold joint may happen. Tin the iron and if using stranded wire tin it as well. I have an adjustable Weller iron 350W-850W and love it they are not cheap but work very well.
CarlC
11-12-2007, 07:59 AM
I too have a Weller. I don't remember what wattage it is, but it has been a great tool. Most real electronic supply stores carry them.
thedugan
11-12-2007, 03:47 PM
I use one from Sears. Works great even on 10 and 12 gauge wire wound together as a splice. Its important to keep the iron below the wire and let it heat up the wire. Press the solder (automotive solder) against the wire and it will melt like butter.
nekkidhillbilly
11-12-2007, 08:16 PM
weller has my vote
Rolling_Thunder
11-13-2007, 03:25 PM
I have a weller at work and it works alright... but then again the best iron i have is some old (older then i am) huge spear looking thing... but Weller has my vote
