View Full Version : Need Help On Primer
jag4902
11-08-2007, 07:41 AM
Have sanded my car down to metal.
Now I am asking for recommendations on what would be the best way to go from here. Primer, basecoat, clear, etc.
My first paint project.
Thanks.
danbob67
11-08-2007, 09:26 AM
if you got bare metal go with a epoxy type primer first.
dhutton
11-08-2007, 10:33 AM
It's not a good idea to leave a car in bare metal for any length of time. It should be coated with epoxy primer very soon as stated above.
Don
jag4902
11-08-2007, 01:17 PM
Is there a specific primer you recommend?
Brand and part number?
Thanks.
dhutton
11-08-2007, 02:34 PM
One reasonably cost effective option is the epoxy from Southern Polyurethanes that you can have shipped to you. I've also used their 2K high build primer. Barry is very helpful and they ship quickly, usually the same day.
www.southernpolyurethanes.com (http://www.southernpolyurethanes.com)
DP40 (different colors are available, for example DP90) from PPG is another option that you can probably find locally.
Make sure you wear a high quality respirator. Epoxy primer is some serious stuff that you don't want in your lungs.
Lots of good information over on camaros.net in the bodyshop forum and also in the tech archives.
Don
danbob67
11-09-2007, 09:08 AM
and the dupont version is also avail. in different colors the med gray is 2540s. If you got a local paint store Im sure they can tell you which brands they carry.
z4me69
11-09-2007, 05:05 PM
ppg dp90
rocketrod
11-09-2007, 07:59 PM
ppg dp90 and then a coat of k36 high fill primer
jag4902
11-15-2007, 01:53 PM
OK, I was told that if I use PPG, Dupont, etc, then it is best to use the same brand for paint, reducer and clear.
danbob67
11-15-2007, 03:10 PM
You can use different primer than the finish coats but It is a good Idea to keep all the same brand products.
jag4902
11-19-2007, 12:54 PM
OK, Thanks.
