View Full Version : power steering pump and bracets for 1st gen
Moose
11-08-2007, 06:02 AM
I'm swapping over to a lsx motor this winter. I've picked up pretty much the entire long block at this point. I have the f-body water pump, f-body alternator and bracket..
problem I'm having is locating a power sttering pump and bracket.. Is there anything aftermarket I can get without breaking the bank?
thanks
Steve1968LS2
11-08-2007, 06:55 AM
If you're running the f-body stuff then why not just run the f-body PS pump and bracket???
You can get them fairly cheap at a wrecking yard or new through Sean Carter at www.smcperformance.com
Moose
11-08-2007, 10:10 AM
Steve.
I've checked tech, local places and can not seem to find one.. I'm fine with running the stocker.
any suggestions?
Steve1968LS2
11-08-2007, 10:23 AM
Steve.
any suggestions?
Yea, the link I supplied above should be able to get you taken care of. It's were I got my brackets, hoses, and pump for Penny.
I then had the pump modified by Turn One Steering.
Moose
11-08-2007, 04:18 PM
I got the brackets I think, but he said pump was bad.. So I'll give the link above a try for the pump.. thanks steve.
trapin
11-09-2007, 08:21 AM
Is there any special way that the LS1 pump needs to be adapted to fit the original Saginaw Steering Box? I'm guessing new hoses are needed.
