View Full Version : Wilwood 12.19 with 15" wheel?
Fuelie Nova
11-01-2007, 11:40 AM
Getting ready to order a complete brake setup for my Nova. Has anyone tried using the wilwood 12.19" rotors under 15" steel wheels? Mine are Cragar SS wheels with 4 1/8" backspacing.
Tom
neki67
11-01-2007, 02:39 PM
In combination with the Dynalite II caliper I know it will fit certain 15" wheels, not sure if it will fit any 15". I know it isn't a conclusive answer but at least I'm not telling you it will not fit no matter what!
matthimself456
11-01-2007, 05:04 PM
Gm used 12 inch rotors behind wheels of both steel and aluminum on Police / towing package Caprices. Not sure if that helps at all.
ProdigyCustoms
11-03-2007, 09:42 AM
The 12.2 is to large to fit the front. It they do fit the rear due to caliper offset.
Fuelie Nova
11-03-2007, 10:05 AM
Thanks Frank...
I am only concerned about the rear, I can use the 11" on the front.
Maybe a little trial and error time.
Tg
ProdigyCustoms
11-04-2007, 07:09 AM
No problem, we should be able to get it done on the rear unless you have some crazy positive offset.
