jeffandre
11-01-2007, 10:24 AM
If your suspension sticks/squeaks/binds, follow this advice: I replaced my urethane control arm bushings with del-a-lum's from GW, even though I had to custom machine them to fit my arms, it was well worth it. With the sway bar removed, the front suspension moves so well it is amazing. The GW bushings mods took about 10 hours.
I connected the sway bar, with its urethane bar to frame bushings and all that smoothness was gone. With no money for a new bar with real bushings (Speedway Engineering), I decided to install grease fittings on the bushing brackets, and carve grease channels into the insides of the bushings where they contact the bar.
On reassembly, I used a lot of poly bushings lube on the bushing parts that contact the bushing brackets and frame, and a lot of grease on the inside of the bushing. Once bolted up, the sway bar moved smoothly with no squeaks and the suspension travels fantastic. What a difference!!!
Totally worth doing! The sway bar work took about 3 hours, using a drill, tap for the Zerk fitting, and a small razor knife setup to carve the channels into the inside of the bushings. I used a very small disc on my drill that barely fit into the bushing and drilled a radial channelf or the lube to move from the grease point into the bushing, then used the razor knife to carve 8 separate lateral channels, stopping each channel about 0.25 inches from the edge of the bushing.
