firstgenfire
10-31-2007, 09:06 PM
I am trying to bolt up a set of coilovers for the front from QA1 on a 67 firebird coupe. These are just the economy set not the pro ones. For some reason the bracket that the coilover mounts to does not want to fit through the bottom of the lower control arm. In the instructions it asks to place the bracket with the "ears" up or down through the hole. It seems like what they are describing is that the plate needs to be mounted on the bottom of the control arm with the ears either facing up through the shock hole or down towards the ground. Mine seems to only fit if I bolt it directly on top of the shock mount on the control arm. This causes the shock and coil setup to be too long and leave no room to tighten to place the spindle back in. Uh this is hard to describe for some reason but has anyone used these coilovers on one or a camaro?
Derek,AZ
Derek,AZ
