View Full Version : Need Help with Front Disc Brake Kit for 17x8.5 Wheel
Tim_in_NC
01-13-2005, 12:04 PM
Hi Guys...
I should specify that this is for the '68 Camaro...
Here's my suspension setup ideas...
Hotchkis 2" Drop Springs in Front
Hotchkis 1.5" Drop 3-Leaf Springs in Rear
KYB Shocks all around
Torque Thrust II Wheels --
Front - 17x8.5 with 5" Back Spacing
Rear - 17x9.5 with 5.5" Back Spacing
Tire Size of --
Front - 245/40/17
Rear - 275/40/17
I'm looking for a Front Disk Brake Kit that will allow me to use the 17x8.5 wheel without rubbing... If I need to change the front wheels out or backspacing...I can...but would like to keep as is and find a Front Disk Brake system that will work...
Anyone out there running a similar setup?
TIM
68BNUT
01-13-2005, 01:14 PM
why dont you just get 8's in the front and 10's in the rear?? I have 17X8 4.5bs in the front stock suspension for now and they only rub on the bottom bolts of the fenders. You may want to watch the 5"bs on the front it may not fit your steering linkage. I bought the 12 wilwood 4 piston setup for the front and they fit fine.
Tim_in_NC
01-13-2005, 02:41 PM
Will 17x10 Torque Thrust wheels work with the 5.5 backspacing in the rear with no prob... No rubbing of the inner fender or no sticking way out...Wider is better
It would be cool to see someone's setup...
As for up front... I can do 8's up front with the backspacing requested...if what I have listed is pushing it too close...
I'll probably be going with a Front Disc Brake Kit...one that comes with Master, lines, etc... One very similar to what Mike's 1st Gen is showing in their cataloge...
I'm just trying to get the whole wheel/Tire thing nailed down before purchasing...
1968SS
01-13-2005, 03:53 PM
Some disc brake kits will not fit TTII's, depends on how big of rotors you want. Baer's 13" track kit will work (it is basically C4 Corvette rotors and calipers) You can download templates from their website to check if their brake kits will fit your wheels. Touring Classics and Speedtech offer 13" kits that use the stock spindles and drum brake hubs (you have to machine them down). Their 13" C5 Corvette rotor and caliper kit will not fit TTII's but their hybrid kit (C4 rotors and C5 calipers) are supposed to fit. You can also download templates from Touring Classic's website. Hope this helps.
Cheers
Steve
Tim_in_NC
01-13-2005, 06:17 PM
Thanks Steve...
TIM
JayBird
01-14-2005, 05:18 AM
for TT II's and wheels that style 17x8x4 3/4 BS and 17x9.5x5 1/2 bs is the best for tucking the wheel under the fender and no contact with tierod. I have the wheel vintiques with those measurements and no problems at all. If you were going with Budniks, DSE recommends 17x8x4 7/8" for front.
JayWeb who is a member here is running the exact whel setup as I mentioned above with TT II's.
BTW....I see you are from Raleigh. I live in Pittsboro and work in RTP. Welcome to the site.
Tim_in_NC
01-14-2005, 12:34 PM
Cool...
Thanks...I've been noticing several guys on this site from the Triangle area...
I use to work up in RTP at Nortel a while back...
Thanks for the info on the wheels...
TIM
CarlC
01-16-2005, 09:42 PM
Tim,
If interested, check out my website on how to fit 275/40/17's on all four corners. The car also has 13"/12" disk brakes.
Conekiller13
01-18-2005, 08:48 AM
I would go with the Baer set up. The calipers are pretty low profile and clear most wheels. The kit moves the wheel out I think 5/8". Plus the kits are complete.
