View Full Version : '70 Camaro Build
Crafty One
10-26-2007, 05:38 PM
Still have not come up with a name for this build....:hmm:
How the body looked when I picked it up...
Crafty One
10-26-2007, 05:41 PM
Replacment subframe and all new front end parts
Crafty One
10-26-2007, 05:45 PM
10 gal of bondo in the rear quarter.... car looked like it took a nasty hit in this side
so off comes the quarter
Crafty One
10-26-2007, 05:50 PM
The roof was completely rusted out under the moulding above doors. The stock roof was not worth fixing.... After some bracing off it came...
class67
10-26-2007, 05:52 PM
Looks fun, keep us posted! Another one saved...:jump:
Crafty One
10-26-2007, 06:02 PM
Donor roof from a totaled 78 installed.
Still need to finish up the fitting at the sail panels. Grafting in the 78 roof takes alittle extra metal work right were the sail and roof meet.
Obsin71Ls1
10-26-2007, 07:46 PM
You my friend, are a brave man. Keep it up.She'll be a beaut when done
Young Gun
10-27-2007, 09:48 AM
make it the first phantom 2nd gen convertible!!!!!!!!!!!! hahah your very daring...i wish i had your skills!
Crafty One
10-27-2007, 05:42 PM
I actuall entertained the idea of making it a convertable, but did not have access to a good donor car to get parts from.... a gen 2 convertible would have been something different....
art wiggins
10-27-2007, 06:27 PM
I had a 2 gen f body. I agree you are a brave man.
Crafty One
11-05-2007, 03:38 PM
Got all the bushings and ball joints installed in the control arms this weekend..... Did some mock-up with the front bags and lower arms.... I have not trimmed for the bags yet, but I have plenty of clearance with these RE6's
Ride height
Show stance... got more clearencing to do at this height
twosaturns
11-05-2007, 06:04 PM
it has been done, back in the day there was a company doing 3rd party conversions, in like 80, 81. last season of charlie's angels, when they moved the operation to hawaii, they had 'em (man, I AM a geek!)
btw, holy crap! you've got a lot of work on that '70! keep at it!
Crafty One
11-18-2007, 07:44 PM
got most of the front suspension finished this weekend..... Just missing the sway bar and shock relocators.
spent some time machining some gen 3 camaro brake rotors for the addition of C5 front brakes.... still need to install some ARP studs
Rotor on right is stock.... left is after machining
Motown 454
11-18-2007, 07:53 PM
Progress looks good keep the pictures comming
There's a convertible 81 firebird for sale in the for sale forum.
What are you doing to treat the rust crafty on the inner panels? Best of luck with the car. I'm glad you're saving it.
Crafty One
11-19-2007, 05:33 AM
I picked up some weld thru primer and some other coating from eastwood co..... the name escapes me right at the moment..... I'll have to take a look at it when I get to the house later.... I'll coat everything after a quick media blast.... Can't blast it right now, got to get it rolling so I can move it outside....
Crafty One
11-19-2007, 05:19 PM
Put the suspension thru some cycles this evening.... here it is with the crossmember only about 3/4" off the floor.
The upper ball joint is maxed out.... so it's not going any lower without changing the UCA's
Crafty One
11-28-2007, 06:26 PM
Of course the car does not sit low enough..... Bring on the 2" Frame Z :scared:
I'll finish lining up my marks tomarrow evening and go ahead and get the sides welded. then start cutting the filler plates.
HectorM52
11-28-2007, 06:38 PM
Cool project. You're brave for taking on that rusty of a car! Thank goodness I live in the South! boooo Rust Belt booooo!!
amargari
11-28-2007, 06:53 PM
Very cool project. When you cut the frame and raised it 2 inches in the front. What are you going to do to the core support to handle that chop?
Crafty One
11-28-2007, 07:06 PM
Being to close to the beach does not help either..... This car lived most of its life in Panana City Fl.....
I'm going to lower the frame horns 2" just behind were the bumper brackets bolt to the frame.
gearheads78
11-28-2007, 07:12 PM
Started as one of the rare "Tooroof" models. Nice work so far.
70BUICK4DOOR
11-29-2007, 11:25 AM
looking good cant wait to see it finished
streetrod77
11-29-2007, 03:13 PM
thanks for keeping us up todate with the project
Crafty One
11-29-2007, 05:45 PM
Well.... I go the frame welded tonight..... but I'm kind of pissed at myself.... If you look in the pictures I had two lines. The lower of the two was my original mark and the top was the second. Well dumb ol' me lined everything up with the original mark.... so It looks as if the "Z" is going to only be 1.5" instead of 2".... :banghead:
Crafty One
01-06-2008, 07:40 PM
Not much for updates.... but I did push the car outside to clean out the garage so I snapped a couple of pics..... I'm waiting on a few part to come in so I can start building the rear 4-link.
XTRMEASURES
02-15-2008, 09:22 AM
did you ever get the parts for the 4-link
Crafty One
02-15-2008, 09:46 AM
Yes I did.... Have not had a whole lot of time to work on the car since both of my girls keep passing some bug back n forth....
I have the lower bars and bag mounts mounted to the axle (ford 9"). I'm in the process of building the cross member of the front lower mounts. Will post some pics by the end of the weekend...
Ryan
formula
02-15-2008, 10:19 AM
I thought mine was low...that's some SERIOUS tuckage!
What are you going to do for inner fenders?
Crafty One
02-15-2008, 12:11 PM
Going to rob the old trailer for the front ones...LOL.... I am going to use trailer fenders. It will help with the fender structure since they are 16ga steel. Still undecided about the back. I'm trying to keep some sort of back seat.... and that is not going to be easy....
Crafty One
02-18-2008, 07:11 PM
Here are a couple of slow progress pics....
The front cross member and lower bar mounts.
and a quick shot of the rear... I'll get a better pic when I pull it out for final fitment and welding of the brackets.
Crafty One
02-20-2008, 06:31 PM
Thought I'd snap a pic befor sliding it under the Camaro
shot looking thru the rear floorboard
One more looking from the rear.... The whole assembly still needs to come up quite a bit more
hotrdblder
02-20-2008, 07:36 PM
not sure whats up, however i would not install the rear control arms at that angle, you need to channel the body and or channel the susp mounting points
Crafty One
02-21-2008, 04:36 AM
That is not its final spot.... I did not get around to cutting the stock frame rails to move the cross member up. The top of the exhaust cutouts will be about 1/2" higher than the stock floor in that area.
trapin
02-21-2008, 05:07 AM
Interesting build. How much lower do you think the front end will go with the motor and trans in there? Also...is this an Air Ride suspension that you're using or another manufacturer? I only ask because I thought the Air Ride stuff came with it's own control arms.
Looking good.
Crafty One
02-21-2008, 06:13 AM
The front will not go any lower.... In the pic with the air let out that is with the LCA's touching the frame. The air suspension is not a kit.... It is however based on the design of the AirRide Cool Ride front kit for the gen2's. Just built it myself to save alittle $$$. Eventually in the long term the whole front will get redone with a custom subframe, but I'm trying to keep my attention on the rear suspension and body and get the stance right.
Johnny Blaze
02-21-2008, 08:04 AM
Loving it!
Crafty One
02-21-2008, 06:37 PM
Tonights progress....
steveo346
02-25-2008, 12:55 PM
nice build bro.....
subscribing...
i have a 72 camaro that i wanna do the same too
Crafty One
03-15-2008, 05:31 PM
Not much for an update.... Rear cross member is in for the last time. I still have not decided what to do about the upper links.... I'm actually leaning to a 3-link w/ a watts....:hmm:
Here are a few pics for enjoyment
Young Gun
03-15-2008, 08:07 PM
hahah well it is definately sitting better! looks good
Crafty One
04-06-2008, 04:32 PM
Not much again, but another update......
Removed the rest of the floor pan, and floor bracing. Installed new mounts for the front cross member/floor brace. This moved it's mounting point up 1.5" into the body. I will be moving the front frame mounts up 1.5"'s also to match.
Crafty One
04-15-2008, 05:41 PM
Removed the lower half of the fire wall.... outer cowl panels and found were the rest of the rust was hiding......
Does anyone have any ideas for this area? There are no replacment panels for this spot on my year. I am contemplating cutting it all out and starting over with a complete frame.....:hand:
Young Gun
04-15-2008, 05:46 PM
DO IT DO IT DO IT!!!
Crafty One
04-25-2008, 12:50 PM
Most current pics..... :eek:
syborg tt
04-25-2008, 05:52 PM
my god - someone stole your body
Crafty One
04-25-2008, 07:24 PM
LOL.... It's sitt'n out in the backyard waiting on me to get a plan going.... :hmm:
jackfrost
04-28-2008, 05:59 AM
now THAT's a short wheelbase! :razz:
jayb53guy
09-12-2008, 05:31 PM
Any updates? I followed this earlier this year. I'm just down the road in Destin.
Don't lose faith!!!
Crafty One
09-12-2008, 05:47 PM
Have not had anytime to work on it... still sitting in the backyard under a tarp till I decide which way I really want to go with it.... I'm kind of tied up with a motorcycle that I'm building for a guy and re-bagging my buddies 03 s-10....
I'd really like to find a decent donor car or use mine for a few needed parts. I'll be bringing something back to the table here the first part of '09
birdsandbowties
09-15-2008, 05:39 PM
looking pretty cool !! love those 70-73 camaro's !! the roof looks a little familiar !
Crafty One
09-15-2008, 05:48 PM
It should look very familiar.... too bad you don't ahve a nice 70-73 body to go with it....
BritishGreen68
09-15-2008, 07:04 PM
my kind of project! All about the SLAMMED.:bananna2:
Crafty One
03-22-2009, 05:05 PM
Update:
The car has a new owner.... I sold the body to a dirt track racer... It was sad seeing it go, but this was for the best.
I've been busy building an SFBD S10 for a buddie of mine. Hoping to revisit the PT world with a new project this summer....
Anyone know were I can find a 2nd gen 2dr 4wd (non zr2) S10 blazer?
HectorM52
03-22-2009, 05:29 PM
You need to get onto www.s10forum.com - those guys are doing SFBD's all day long. Might even find a truck you want.
However I suggest you get on www.s-seriesforum.com/forum - a better group of guys in my opinion.
Find your truck on Craigslist. Just keep an eye out. A new search engine I've foiund is www.craigshelper.com - it lets you search regionally/locally.
