View Full Version : gm 10 bolt pinion play
Takid455
10-25-2007, 08:46 AM
what is the proper amount of play for the pinion and rings gears when setting up a gm 8.5" 10 bolt? I heard .008-.012" for ring gear to pinion gear clearance is accecptable.
10-25-2007, 06:20 PM
for gear lash thats correct. I like to run them right at .008
Tiger
10-26-2007, 02:08 AM
I prefer them tight as well, I always try to run them as close to the lower limit as possible.
Takid455
10-26-2007, 04:54 AM
what about setting up the pinion gear initially? i am planning on using shims as opposed to the crush collar system, is this way better?
10-26-2007, 08:49 PM
you use the shims between the inner bearing and pinion to set pinion depth then the crush sleeve is to set the pinion bearings pre load. i like to set to 22-25 inlbs rotating torque.
chicane67
10-26-2007, 09:58 PM
Lash should also be tuned for the weight of the oil used. If you use a 90wt... 0.008" is good; if you use 140wt... 0.010". This will help with getting enought oil into the set to help combat the impact loading.
A solid spacer is the prefered component for performance use. It will definately negate and preload changes like that of the crush type pieces.
68nate
10-28-2007, 06:59 PM
First time I've heard of using a solid spacer. Do you just set it to the same rolling torque?
chicane67
10-28-2007, 08:04 PM
Yes...
strangler
10-29-2007, 06:48 AM
you use the shims between the inner bearing and pinion to set pinion depth then the crush sleeve is to set the pinion bearings pre load. i like to set to 22-25 ftlbs rotating torque.
Don't you mean inch pounds?
Skip Fix
10-29-2007, 09:51 AM
Ratech makes the solid "crush sleeves". They also have shims to put behind the bearign race vs behind the bearing if a press isn't handy.
10-29-2007, 10:44 AM
Don't you mean inch pounds? yep your right. Torque to 200ftlbs then tighten further to get 25 inlbs in rotational torque.
Solid spacer sounds like a good idea. Havent used one yet.
So you put the shim behind the outer bearing race?
